ASA5505 - multiple public IP's
For a branch office we have an ASA5505 connected to the ISP with an DHCP provided public IP "locked" to the local MAC
This works ok!
Now - the ISP may provide up to 5 public IP's (all DHCP assigned).
Is it possible to configure 2-5 public interfaces in the ASA??
As IP's are DHCP assigned there must be something (a interface) to request the address.
Would this be possible, and if so - what license would be required??
NAT routing on the inside should be possible as well.
Thanks.... S
JohnTylerPearce
Level 7
Level 7
Well you can create sub-interfaces out of physical interfaces. So if you have gi0/0, you could create two sub-interfaces
gi0/0.1 and g0/0.2. I see the ISP may provide you will up to 5 public IP's (all DHCP assigned). Are these addresses
always going to be reserved for you or are they going to be regular DHCP? Also, what are the other public IP's
going to be used for?
Ok - how's sub interfaces created in ASA5505??
The IP's are assigned first time as regular DHCP assignments and afterward locked to the MAC address.
IP's are going to the used for different HTTP/HTTPS sites with different certs
So we'll port translate outside1:443 to inside1:443, outside2:443 to inside2:443
The solution is not ideal, but for the purpose in question sufficient :-)
Sounds like the additional IP's are just going to be used for NAT purposes with your sites. To create sub-interfaces yo
do the following
int x
no ip address
no nameif
no security-level
int y
ip address y.y.y.y y.y.y.y
nameif Y
security-level Y
vlan Y
int z
ip adress z.z.z.z z.z.z.z
nameif Z
security-level Z
vlan Z
Although, if you're using the additional IP's just for NAT, there is really no need to create sub-interfaces. But at least
you know how to      Another thing to remember is, if you create subinterfaces and you have the ASA connected to
a switch you will need to make that port a trunk port.
ASA <======> (Trunk on this end)Switch <========> X/Y hpsts
IcebergTitanic
I think you can do it as described above, with subinterfaces, but there are some caveats...
1.  You'll have to name the interfaces, and you'll need more than base license to route between more than two named interfaces if I remember correctly.
2.  Because your external IP addresses will be DHCP'd to you, you'll only be able to nat to the interface addresses, and it might make some of your routing and access controls confusing...
