ASA5512 - 'public' server traffic is being dropped
richard.quick1
I curently have a very simple setup
ISP Router <---outside---> ASA5512 <---inside---> Host
There is nothing else on the ASA yet.
I have configured the host as a public server in the ASDM application, when I try to access the server via the external IP address I get the following error in the log -
Inbound TCP connection denied from x.x.x.x/13183 to x.x.x.x/80 flags SYN  on interface outside
I have have searched other forums and documents and the only suggestions are interface security levels, I have set the inside to 50 and the outside to 0. I can not see how changin this could help though.
Thank you in advance of any help.
Richard
You have an acl allowing the traffic but you haven't applied it to the interface.
You have -
"access-group outside_access in interface outside-virgin"
but it should be -
"access-group outside_access in interface outside"
Jon
5 Replies 5
Jon Marshall
Perhaps post the configuration ?
Jon
Hi Jon,
The configuration is as below, didnt post incase it was an easy fix and save a large post.
Thanks for taking a look
Richard
ASA Version 9.1(2)
hostname firewall-002
domain-name spacedatacentres.co.uk
enable password qtj0RuoLwuInmHYK encrypted
passwd qtj0RuoLwuInmHYK encrypted
names
interface GigabitEthernet0/0
 description ISP Circuit
 nameif outside
 security-level 0
 ip address 62.x.x.x 255.255.x.x
interface GigabitEthernet0/1
 description Internal D001 Network
 nameif inside
 security-level 50
 ip address 192.x.x.1 255.255.255.0
interface GigabitEthernet0/2
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet0/3
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet0/4
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet0/5
 shutdown
 no nameif
 no security-level
 no ip address
interface Management0/0
 management-only
 nameif management
 security-level 100
 ip address x.x.x.x 255.255.255.0
boot system disk0:/asa912-smp-k8.bin
ftp mode passive
clock timezone GMT/BST 0
clock summer-time GMT/BDT recurring last Sun Mar 1:00 last Sun Oct 2:00
dns domain-lookup management
dns domain-lookup outside
dns domain-lookup inside
dns server-group DefaultDNS
 name-server 194.x.x.x
 domain-name xxxxxxx.co.uk
same-security-traffic permit inter-interface
object network 62.x.x.79
 host 62.255.128.79
object network D-000001
 host 192.x.x.10
 description D-000001 Server
object-group service DM_INLINE_TCP_0 tcp
 port-object eq domain
 port-object eq www
 port-object eq https
access-list outside_access extended permit tcp any4 object D-000001 object-group DM_INLINE_TCP_0
pager lines 24
logging enable
logging asdm warnings
mtu management 1500
mtu outside 1500
mtu inside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-713.bin
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (inside,outside) source dynamic any interface
 nat (inside,outside) static 62.x.x.79
route outside 0.0.0.0 0.0.0.0 62.x.x.65 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
http server enable
http x.x.x.x 255.255.255.0 management
snmp-server host management 192.168.1.30 community *****
snmp-server location xxxxxxxx
snmp-server contact xxxxxxx
snmp-server community *****
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
telnet 192.x.x.x 255.255.255.0 management
telnet timeout 5
ssh 192.x.x.x 255.255.255.0 inside
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ssl encryption rc4-sha1 aes128-sha1 aes256-sha1 3des-sha1
username xxxxxx password xxxx encrypted privilege 15
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
  inspect icmp error
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
 profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly 1
  subscribe-to-alert-group configuration periodic monthly 1
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:a52446ba0500580f8d3cb5c569d2006a
: end
You have -
but it should be -
Jon
Hi Jon,
Thats perfect, thank you. Obviously a typo when tidying up the config.
Thank you again.
Richard
No problem.
Jon
