ASA5515-FPWR-K9 able to be configured for PPPoE?
fbeye
Level 4
Level 4
Was curious if this particular device could be configured to act as a PPPoE Client when connected to an ISP Router in Bridge Mode.
If so, would it be a standard configuration like https://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/110322-asa-pppoe-00.html describes?
Also, is the 5515-X predecessor to the 5516-X? Aside from the dadasheets, which they all appear to be the same aside from throughout and access limits, I notice that the 5515-X looks to be a completely different style.
Pros/cons?
Francesco Molino
Yes it should work.
Here the last doc version with recent asa software:
https://www.cisco.com/c/en/us/td/docs/security/asa/asa91/configuration/vpn/asa_91_vpn_config/vpn_pppoe.html
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco Molino
Yes it should work.
Francesco
Thank you. looks good.
You're welcome
Francesco
