Bookmark
Subscribe
615
PAT over PPPoE
I am having trouble figuring out why I cannot ping through my PPPoE connection between SP1 and NY-CPE2 while doing NAT on NY-CPE2.  NY-CPE2 is able to ping R3, but not from extended ping on inside interface.  I can't seem to figure out why NAT, while it appears to be translating it to the correct interface, won't pass my traffic.
SP1-----------SP2--------R3
NY-CPE2<---R1<---R2
SP1=203.0.113.5
R3=192.168.3.2
NY-CPE2=203.0.113.6   ::  192.168.1.1
R1=192.168.1.2  ::  192.168.2.1
R2=192.168.2.2
RESULTS
NAT: Entry assigned id 122
NAT*: ICMP id=42->1024
NAT*: s=192.168.2.1->203.0.113.6, d=192.168.3.2 [307]
NAT*: s=192.168.2.1->203.0.113.6, d=192.168.3.2 [308]
Tracing the route to 192.168.3.2
VRF info: (vrf in name/id, vrf out name/id)
  1 192.168.2.2 252 msec 76 msec 20 msec
  2 192.168.1.1 80 msec 32 msec 24 msec
  3  *  *  *
  4  *  *  *
Interface              IP-Address      OK? Method Status     Protocol
FastEthernet0/0        unassigned      YES unset  up         up
FastEthernet1/0        192.168.1.1     YES manual up         up
Dialer1                      unassigned      YES IPCP   up         up
Virtual-Access1        unassigned      YES unset  up         up
RUNNING-CONFIG
interface FastEthernet0/0
 no ip address
 duplex full
 pppoe enable
 pppoe-client dial-pool-number 1
interface FastEthernet1/0
 ip nat inside
 ip summary-address eigrp 100 0.0.0.0 0.0.0.0
 duplex full
interface Dialer1
 ip address negotiated
 ip nat outside
 encapsulation ppp
 dialer pool 1
 ppp chap password 0 Test123
router eigrp 100
 network 192.168.0.0 0.0.255.255
ip nat inside source list 101 interface Dialer1 overload
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 101 permit ip any any
I have made a few adjustments to your config (marked in bold), see if you get it to work:
no ip address
duplex full
pppoe enable
ip nat inside
duplex full
interface Dialer1
ip mtu 1460
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1420
dialer pool 1
router eigrp 100
ip nat inside source route-map ISP interface Dialer1 overload
access-list 1 permit 192.168.1.0
route-map ISP permit 10
match ip address 1
match interface Dialer1
i added the additional statements, but get the same results where it looks like it's translating correctly, just not leaving the interface.  A ping from CPE2 works just fine, but an extended ping from the 192.168 network interface on f1/0 still looks like the following:
NY-CPE2(config-if)#do sh ip nat trans
Pro Inside global Inside local Outside local Outside global
icmp 203.0.113.6:1024 203.0.113.6:10 203.0.113.18:10 203.0.113.18:1024
icmp 203.0.113.6:1025 203.0.113.6:11 203.0.113.18:11 203.0.113.18:1025
Packet sent with a source address of 192.168.1.1
Success rate is 0 percent (0/5)
NY-CPE2(config-if)#
