12-25-2014 02:11 AM - edited 03-05-2019 12:26 AM
Hi all,
I have a problem with ASA5520 and reverse telnet. I recently upgrade IOS on ASA5520, asa921-k8. Problem is that cisco has latest IOS version asa91x.... for this platform.
I have 7201 on remote site, and connect his aux to asa console. When I do telnet to specific port, this is output:
Low Memory: 631 KB
High Memory: 2048 MB
PCI Device Table.
Bus Dev Func VendID DevID Class Irq
00 00 00 8086 2578 Host Bridge
00 01 00 8086 2579 PCI-to-PCI Bridge
00 03 00 8086 257B PCI-to-PCI Bridge
00 1C 00 8086 25AE PCI-to-PCI Bridge
00 1D 00 8086 25A9 Serial Bus 11
00 1D 01 8086 25AA Serial Bus 10
00 1D 04 8086 25AB System
00 1D 05 8086 25AC IRQ Controller
00 1D 07 8086 25AD Serial Bus 9
00 1E 00 8086 244E PCI-to-PCI Bridge
00 1F 00 8086 25A1 ISA Bridge
00 1F 02 8086 25A3 IDE Controller 11
00 1F 03 8086 25A4 Serial Bus 5
00 1F 05 8086 25A6 Audio 5
02 01 00 8086 1075 Ethernet 11
03 01 00 177D 0003 Encrypt/Decrypt 9
03 02 00 8086 1079 Ethernet 9
03 02 01 8086 1079 Ethernet 9
03 03 00 8086 1079 Ethernet 9
03 03 01 8086 1079 Ethernet 9
04 02 00 8086 1209 Ethernet 11
04 03 00 8086 1209 Ethernet 5
Evaluating BIOS Options ...
Launch BIOS Extension to setup ROMMON
Cisco Systems ROMMON Version (1.0(11)2) #0: Thu Jan 26 10:43:08 PST 2006
Platform ASA5520
Use BREAK or ESC to interrupt boot.
Use SPACE to begin boot immediately.
Launching BootLoader...
Boot configuration file contains 1 entry.
Loading disk0:/asa921-k8.bin... Booting...
Platform ASA5520
This ASA image cannot run on a ASA5520 system.
ÿ
Booting system, please wait...
CISCO SYSTEMS
Embedded BIOS Version 1.0(11)2 01/25/06 13:21:26.17
Low Memory: 631 KB
PCI Device Table.
Platform ASA5520
This is run over and over. I just can't enter a ROMMON mode of ASA. I have older IOS on flash which works.
I don't know what to type to enter in rommon mode. I tried every combinatios of characters but nothing. I used Putty, SecureCRT.
Any idea?
Nenad
12-25-2014 07:13 PM
So ESC isn't working during boot? FYI 9.2 is not supported on non-X ASA chassis (which I'm sure you have now figured out). You can also try changing the escape sequence so ESC will work. Check this link on how to change that.
http://www.cisco.com/c/en/us/td/docs/ios/12_2/configfun/configuration/guide/ffun_c/fcf003.html#wp1003461
Hope it helps.
12-25-2014 10:54 PM
Hi Collin, nothing works. Yes I figured out when I boot asa :) I also tried whith escape character but nothing. I thing that something is wrong whith AUX port on 7201, beacause I cant send anything through cable.
Nenad
