Asking for IOS Feature Set
udimpas
Hi!
Im planning to upgrade the IOs of our Cisco 7206 router. Just would like to clarify if what feature set does C7200-IS-M is? Actual output from "sh ver: (C7200-IS-M) 12.0(6)W5(14).
Thanks in advance!
udimpas
2 Accepted Solutions
thisisshanky
Level 11
Level 11
That would be IP Plus.
PS: please rate the post if it helped you!
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Udimpas,
Z - indicates its a compressed archive.
is - the s indicates that its ip plus.
Sankar Nair
thisisshanky
Level 11
Level 11
Sankar Nair
Thanks for the reply. One more clarification, I have checked with the software advisor but IP Plus has a code of IS-MZ for newer versions. Or maybe because early versions(12.0) of IP Plus has a different code?
Thanks again.
udimpas
Udimpas,
Sankar Nair
Thank you very much! Got it!
regards,
udimpas
