ASR 1000 Boot variable does not exit when doing reload
ahad311
Hi All,
I'm configuring a cisco ASR 1000 and when I attempt to do reload I get below error :
WARNING:
Boot variable either does not exist or buffer is too small This may impact autoboot of the router. Proceed with caution
Do you want to proceed?[confirm]n
when I do show boot I get the below:
BOOT variable does not exist
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
Standby not ready to show bootvar
I haven't restarted the router out of caution. Would appreciate any thoughts on how to deal with this.
6 Replies 6
balaji.bandi
check from prompt
#dir bootflash:
you will see .bin file example  ( asr1000-universalk9.XX.XX.XX.SPA.bin)
note that file name and config as below :
config t
boot system flash bootflash:/asr1000-universalk9.XX.xx.xx.SPA.bin
end
then check show boot you see the boot information (if all ok)
write the config and reload
BB
Thanks mate. That solve my issues
Glad it help to resolved the issue and all good, we mark as resolved now.
BB
Hi Balaj
I am having this same error.  When I followed same resolution steps. It has not helped.
Can you please guide me  ? where i am doing wrong.  thanks
WARNING:
Do you wish to proceed with reload anyway[confirm]
 I am  sharing the results of dir bootflash:
dir bootflash:
Directory of bootflash:/
32065 drwx 32768 Feb 26 2024 11:51:24 +11:00 tracelogs
28 -rw- 13484 Feb 13 2024 16:26:17 +11:00 configbackup-Feb-13-16-26-17.720-19
27 -rw- 13236 Feb 9 2024 11:41:47 +11:00 configbackup-Feb--9-11-41-47.638-18
26 -rw- 13236 Feb 9 2024 11:38:32 +11:00 configbackup-Feb--9-11-38-32.484-17
80161 drwx 4096 Jan 2 2024 13:26:44 +11:00 .installer
48097 drwx 4096 Jan 2 2024 13:26:25 +11:00 license_evlog
19 -rw- 656 Jan 2 2024 13:26:23 +11:00 vlan.dat
16 -rw- 30 Jan 2 2024 13:26:11 +11:00 throughput_monitor_params
12 -rw- 134458 Jan 2 2024 13:25:42 +11:00 memleak.tcl
11 -rw- 2820 Jan 2 2024 13:25:14 +11:00 mode_event_log
25 -rw- 13305 Oct 9 2023 14:33:33 +11:00 configbackup-Oct--9-14-33-33.160-16
24 -rw- 13295 Oct 9 2023 14:32:47 +11:00 configbackup-Oct--9-14-32-47.153-15
23 -rw- 13226 Oct 9 2023 11:45:20 +11:00 configbackup-Oct--9-11-45-20.300-14
22 -rw- 13318 Aug 31 2023 11:14:09 +10:00 configbackup-Aug-31-11-14-09.316-13
21 -rw- 13308 Aug 31 2023 11:11:53 +10:00 configbackup-Aug-31-11-11-53.076-12
20 -rw- 13396 Aug 31 2023 10:46:20 +10:00 configbackup-Aug-31-10-46-19.872-11
30 -rw- 13372 Aug 31 2023 10:40:56 +10:00 configbackup-Aug-31-10-40-56.444-10
112225 drwx 4096 Aug 4 2023 12:54:27 +10:00 .prst_sync
128257 drwx 4096 Aug 4 2023 12:48:11 +10:00 .dbpersist
104209 drwx 4096 Aug 4 2023 12:43:05 +10:00 pnp-tech
18 drwx 4096 Jul 27 2023 12:54:15 +10:00 lost+found
17 -rw- 604115200 Jan 15 2023 05:18:31 +11:00 c1100-universalk9.17.03.04a.SPA.bin
72145 drwx 4096 Jan 15 2023 05:09:38 +11:00 iox_host_data_share
8017 drwx 4096 Jan 15 2023 05:09:27 +11:00 .attrib
56113 drwx 4096 Jan 15 2023 05:09:18 +11:00 guest-share
16033 drwx 4096 Jan 15 2023 05:08:55 +11:00 core
40081 drwx 4096 Jan 15 2023 05:08:52 +11:00 onep
136273 drwx 4096 Jan 15 2023 05:08:49 +11:00 pnp-info
168337 drwx 4096 Jan 15 2023 05:08:09 +11:00 virtual-instance
14 -rwx 1314 Jan 15 2023 05:08:02 +11:00 trustidrootx3_ca.ca
13 -rw- 20109 Jan 15 2023 05:08:02 +11:00 ios_core.p7b
24049 drwx 4096 Jan 15 2023 05:07:50 +11:00 gs_script
152305 drwx 4096 Jan 15 2023 05:07:28 +11:00 .rollback_timer
sh boot
BOOT variable =
the config we provided for Router :
what device moel you having issue ?
as per the bin file it is c1100-universalk9.17.03.04a.SPA.bin   - so above proceedure should work.
BB
Leo Laohoo
Post the complete output to the command "dir".
Cisco ISR & ASR 1k Routers: IOS-XE/Firmware Upgrade (Install Mode)
