configuring gre between two routers where ospf is used for routing
amalmkrishna21
i want to make a gre tunnel between router1 and router 2, and I also make it but still when I do tracert from one of my PCs to the PCs in the other network I don't see any working of the GRE.
ROUTER 1 RUNNING CONFIG
Building configuration...
Current configuration : 964 bytes
version 15.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
ip cef
no ipv6 cef
spanning-tree mode pvst
interface Tunnel0
ip address 172.16.0.1 255.255.0.0
mtu 1476
tunnel source GigabitEthernet0/0/1
tunnel destination 20.0.0.2
interface GigabitEthernet0/0/0
ip address 192.168.1.5 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/0/1
ip address 10.0.0.1 255.0.0.0
duplex auto
speed auto
interface GigabitEthernet0/0/2
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
router ospf 50
log-adjacency-changes
network 192.168.1.0 0.0.0.255 area 0
network 10.0.0.0 0.255.255.255 area 0
network 172.16.0.0 0.0.255.255 area 0
router rip
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
ROUTER 2 RUNNING CONFIG
Current configuration : 951 bytes
version 15.4
hostname Router
ip cef
no ipv6 cef
interface Tunnel0
ip address 172.16.0.2 255.255.0.0
mtu 1476
tunnel destination 10.0.0.1
ip address 192.168.2.5 255.255.255.0
duplex auto
speed auto
ip address 20.0.0.2 255.0.0.0
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
router ospf 50
network 20.0.0.0 0.255.255.255 area 0
network 192.168.2.0 0.0.0.255 area 0
ip classless
line con 0
line aux 0
line vty 0 4
login
end
tracert result from pc0 to pc3 is attached as a screen shot
pls help me and tell me how to make the gre work so that the packet goes through gre instead of the normal internet.
all the routers have ospf configured as routing algorithm
the router model used is ISR4331
It looks like you have underlay connectivity, however, your tunnel interfaces are also using the same routing protocol as your underlay. This produces a Recursive routing issue, meaning your tunnel endpoint is being learned through the tunnel itself as its built...which cannot happen. Try using another routing protocol for the Tunnel interfaces like EIGRP or even static routes.
To have traffic flow over the tunnel it needs to be built.
-David
7 Replies 7
-David
If you don't understand @David Ruess's answer, let us know.
Hello
You need to make sure you can reach the tunnel source/destination addresses and that addressing is NOT being advertised over the tunnel
hostname Router
router ospf 50
no network 10.0.0.0 0.255.255.255 area 0
ip route 10.0.0.0 255.0.0.0 gig0/0/1 20.0.0.X
ROUTER 2
router ospf 50
no network 20.0.0.0 0.255.255.255 area 0
ip route 20.0.0.0 255.0.0.0 gig0/0/1 10.0.0.X
Kind Regards
Paul
amalmkrishna21
Hai,
I saw that both @David Ruess and @paul driver have suggested using static routing so I did the following using @paul driver command:
Router1
router ospf 50
exit
ip route 10.0.0.0 255.0.0.0 20.0.0.2
Router2
router ospf 50
exit
ip route 20.0.0.0 255.0.0.0 10.0.0.1
but still, it didn't work, the tracert did not even reach the destination, the output I got I have attached a screenshot below.
so later I did the following without changing the static routing.
Router1
router ospf 50
exit
Router2
router ospf 50
exit
then I was able to do tracert and it reached the destination, but still, it didn't use the tunnel for it.
so I tried to remove the route from the OSPF by doing the following:
Router1
router ospf 50
exit
Router2
router ospf 50
exit
but again the tracert was not complete.
I am a beginner so I don't have much knowledge on how all these works, so pls forgive my ignorance or stupidity. please do let me know if there is any way to attach my pkt file so that everyone can look at it carefully.
Thank you.
amalmkrishna21
Hai,
I was just reading @David Ruess's answer then I understood what it meant so I did the following
Router1
router ospf 50
exit
Router2
router ospf 50
exit
then I added the static routing as per @David Ruess and @paul driver, I have attached the screenshot for static routing for both the routers below.
And now I can do tracert through the tunnel, I have also attached the screenshot below.
Thank you @paul driver and @David Ruess for solving my doubts by taking your precious time, forever grateful to you guys. Maybe you guys explained to me properly why my network was not working as intended and that I did not get it properly because I am new to all this, I don't know the in depth knowledge of how all these routing, VPN, etc work. I only have a surface level knowledge about all this stuff.
for those wondering what my current configuration is:
1. I configure ospf routing algorithm as usual for all my routers, and checked whether the packet is going from one network to the other.
2. Then as per @David Ruess and @paul driver's suggestion I also added static routing algorithm for the tunnel interface in both routers.
3. Now the tracert is going through the tunnel.
May god bless you all.
"Maybe you guys explained to me properly why my network was not working as intended and that I did not get it properly because I am new to all this, I don't know the in depth knowledge of how all these routing, VPN, etc work. I only have a surface level knowledge about all this stuff."
Yup, I suspected that might be the case, especially when @David Ruess mentioned recursive routing, which is why I wrote my first reply.
In the future don't be "shy" to ask for more information.  Almost all posters will happily supply it, especially VIPs or Hall of Fame members, who got those ratings trying to be helpful.
Sure Joseph, Thanks, God bless you
