ASR 1000 - DHCP server on interface with only static IP
dominiaz
How to make DHCP server on ASR 1000 with only static IP - IP binded with mac?
6 Replies 6
M02@rt37
Hello @dominiaz
You can configure a DHCP server to assign IP addresses to clients based on their MAC addresses. This is known as DHCP address binding or DHCP reservations.
As example:
ip dhcp pool MY_POOL
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8
host 0011.2233.4455 192.168.1.10
host 00AA.BBCC.DD22 192.168.1.20
This example assumes a subnet of 192.168.1.0/24, a default gateway of 192.168.1.1, and DNS server 8.8.8.8. The two hosts with MAC addresses 0011.2233.4455 and 00AA.BBCC.DD22 will be assigned static IP addresses 192.168.1.10 and 192.168.1.20, respectively.
Best regards
(dhcp-config)#host 0011.2233.4455 192.168.1.10
% Invalid input detected at '^' marker.
Ok @dominiaz
separate like this:
ip dhcp pool CLIENT_10
host 192.168.1.10 255.255.255.0
client-identifier 0011.2233.4455
ip dhcp pool CLIENT_11
host 192.168.1.11 255.255.255.0
client-identifier xxxxx
ip dhcp pool CLIENT_12
host 192.168.1.12 255.255.255.0
client-identifier yyyyy
Best regards
Working:
client-identifier 013e.f86b.b174.f5
Not working:
hardware-address 3ef8.6bb1.74f5
Why?
https://mrncciew.com/2013/06/10/ios-dhcp-add-reservation/
Both must be work but some time device send different mac that it appear in show interface' so we use cleint id option which can not modify or change.
MHM
