Cannot ping router from PC using a L3 switch
purple12
I am practicing for my CCNA and I have set up a layer 3 switch in packet tracer with a few pc's and on 2 different VLANS and a DHCP server.
I can ping everything on the network from any of the pc's including the switch but I cannot ping the router. I can't see what I have missed, I have attached the packet tracer file. Could someone take a look, its driving me nuts!
2 Accepted Solutions
M02@rt37
Hello @purple12
Please add default static route on Router R1:
After that, you will be able to ping 192.168.5.1 from PCs
Best regards
You're so welcome @purple12
When you ping from PCs this IP [192.168.5.1] hosted on that Router R1, the echo-request reach this IP but, the resposne, e.g. the echo-reply from R1's IP address towards PC's IP is not routed since you have no route on your routing table! The fact that you configure a default route towards Sw L3 send the echo-reply to that L3 Swtich!
You could be more effective if you add this route on R1 instead of default route:
Best regards
M02@rt37
Hello @purple12
Best regards
Hi M02@rt37 that worked thank you, could you explain why I needed to add that please?
Best regards
