ASR 1000 software upgrade
Anukalp S
Hi.. i am looking to upgrade ASR 1002, 2RU router from software ver.  asr1000rp1-adventerprisek9.02.04.00.122-33.XND.bin to asr1000rp1-adventerprisek9.03.16.08.S.155-3.S8-ext.bin. Also running current Rommon ver 12.2(33r)XNC.
Please confirm if i would need to upgrade Rommon ver also to support new software version.
Also confirm if this is directly upgrade to this new version.
Mark Malone
the release notes dont specifically say a certain rom or interim image is required to get to 3.16 , heres the guide below , usually when not stated its not required and you can just jump direct
https://www.cisco.com/c/en/us/td/docs/routers/asr1000/release/notes/asr1k_rn_rel_notes/asr1k_feats_important_notes_316s.html
I can tell you though i am running this below on my ASR1001Xs and my rom is 15.4(2r)S and it has worked fine the last year
xxxxxxxxxxxx#SH VER | I asr
System image file is "bootflash:asr1001x-universalk9.03.16.07b.S.155-3.S7b-ext.SPA.bi"
xxxxxxxxxxxx#sh rom-monitor rp active | i 15
System Bootstrap, Version 15.4(2r)S, RELEASE SOFTWARE (fc1)
whats the current ROM show as ?
personally if the rom is very low i would jump to high end of 15 or 16 , at least then the ROM is up to date for future upgrades even if not required now
https://software.cisco.com/download/home/282046548/type/282046486/release/16.3(2r)
Leo Laohoo
You will definitely need to upgrade the ROMmon.
