OSPF not working
Alex Hall
I have two routers connected with serial interfaces and to begin with I was unable to ping either router, anyway I want to configure OSPF 100 with the routers on area 0 the current configs are
Router 1:
Building configuration...
Current configuration : 1077 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname HQ
enable secret 5 $1$mERr$Kf7LJHoCqrlN7frh/vXzO1
enable password ttf1234
ip cef
no ipv6 cef
username ttfadmin privilege 15 secret 5 $1$mERr$sGPHml/Zec.vL6mmhKJAd0
no ip domain-lookup
spanning-tree mode pvst
interface FastEthernet0/0
no ip address
duplex auto
speed auto
shutdown
interface FastEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Serial0/0/0
ip address 10.10.10.2 255.255.255.252
ip ospf 100 area 0
interface Serial0/0/1
ip address 10.20.20.2 255.255.255.252
ip ospf 100 area 0
clock rate 64000
interface Vlan1
no ip address
shutdown
router ospf 100
log-adjacency-changes
network 10.10.10.0 0.0.0.3 area 0
network 10.20.20.0 0.0.0.3 area 0
neighbor 10.10.10.1
neighbor 10.20.20.1
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
password ttf12345
login local
end
Router 2:
Current configuration : 1044 bytes
version 12.4
hostname Adelaide
enable secret 5 $1$mERr$KZJUS7CY9GPgCalBziSwO1
enable password ttf123456
ip cef
no ipv6 cef
no ip address
duplex auto
speed auto
shutdown
ip ospf 100 area 0
duplex auto
speed auto
ip address 10.10.10.1 255.255.255.252
ip ospf 100 area 0
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
router ospf 100
network 192.168.1.0 0.0.0.255 area 0
neighbor 10.20.20.2
ip classless
line con 0
line aux 0
line vty 0 4
password ttf1234567
login
end
Router 1 also has another router it's connected to but it's just a mirror of router 2, I'm not sure what I've done wrong, can someone provide some help, please excuse the ignorance I'm new to this.
Thanks in advance.
Your still missing the clock rate command thats whats required on DCE side
clock rate 64000
21 Replies 21
Mark Malone
are the serial interfaces up/up ? show interface sx/x , you dont need the neighbor commands or shouldn't require these either under the interfaces ip ospf 100 area 0 as you have set the subnets under the process , have you set the clock rate on the DCE side too i dont see it under either 10 range network interface ?
most connections are ethernet now if your practicing this for a LAB , serial is nearly gone too slow nowaday
https://www.cisco.com/c/en/us/support/docs/ip/open-shortest-path-first-ospf/13687-15.html#conf1
Hey mate both interfaces are up yes
I was labbing this up in GNS3 while Mark provided the answer, so my apologies if I am being redundant. Either way, the below should be sufficient to establish a FULL adjacency:
Router 1:
clock rate 64000
router ospf 100
Router 2:
router ospf 100
Hi mate I reconfigured the routers to match yours and I'm still not getting a ping, I'm really stuff for this, I'll include the updated configs below. Cheers.
Router 1:
Current configuration : 995 bytes
version 12.4
hostname HQ
ip cef
no ipv6 cef
no ip domain-lookup
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
clock rate 64000
interface Vlan1
no ip address
shutdown
router ospf 100
ip classless
line con 0
line aux 0
line vty 0 4
password ttf12345
login local
end
Router 2:
Current configuration : 945 bytes
version 12.4
hostname Adelaide
ip cef
no ipv6 cef
no ip address
duplex auto
speed auto
shutdown
duplex auto
speed auto
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
router ospf 100
ip classless
line con 0
line aux 0
line vty 0 4
password ttf1234567
login
end
Adelaide#show run
version 12.4
hostname Adelaide
ip cef
no ipv6 cef
no ip address
duplex auto
speed auto
shutdown
duplex auto
speed auto
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
router ospf 100
ip classless
line con 0
line aux 0
line vty 0 4
password ttf1234567
login
end
clock rate 64000
So when i tried to set clock rate on router 1 serial0/0/1 it let's me but for router 2 serial0/0/0 it doesn't allow me saying "This command applies only to DCE interfaces
Hello
you have confirmed if this Is this a GNS lab or physical routers, Are these routers directly connected?
It looks like from your configuration your encapsulation is HLDC is that correct?
show interfaces serial0/0/0 | in up| En
sh controllers serial0/0/0 | in DCE|DTE
Kind Regards
Paul
This is built in packet tracer
Would you post the output of these commands on both routers.
show ip interface brief
show cdp neighbor
Rick
Rick
Cheers for the reply here you go,
Router 2:
Adelaide#show ip interface brief
FastEthernet0/0 unassigned YES unset administratively down down
FastEthernet0/1 192.168.1.1 YES manual up up
Serial0/0/0 10.10.10.1 YES manual up up
Serial0/0/1 unassigned YES unset administratively down down
Vlan1 unassigned YES unset administratively down down
Adelaide#show cdp nei
Adelaide#show cdp neighbors
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone
Device ID Local Intrfce Holdtme Capability Platform Port ID
S1 Fas 0/1 169 S 2960 Fas 0/1
HQ Ser 0/0/0 152 R C1841 Ser 0/0/1
Router 1:
HQ#show ip interface brief
FastEthernet0/1 unassigned YES unset administratively down down
Serial0/0/0 10.10.10.2 YES manual up up
Serial0/0/1 10.20.20.2 YES manual up up
HQ#show cdp nei
HQ#show cdp neighbors
Sydney Ser 0/0/0 146 R C1841 Ser 0/0/1
Adelaide Ser 0/0/1 171 R C1841 Ser 0/0/0
The output of show ip interface brief confirms that both interfaces are up/up
And the output of show cdp neighbor confirms that they see each other
HQ#show cdp nei
So it looks like it should work. But if you look carefully you will notice that the connection should be s0/0/0 to s0/0/0
But if you look carefully you will notice that the connection is actually s0/0/0 to s0/0/1
HQ#show cdp nei
So the issue is that physically the interfaces are cross connected. This is why you can not ping and why OSPF will not form neighbor relationships.
Rick
Rick
SCC HDLC PARSMETER RAM (at 0x68013C00
Packet tracer is not a very friendly simulation for serial connectivity. This appears more to be PT issue as oppose to actual configuration.
What would you recommend instead, are there any other simulation programs that I can use as I don't have access to physical routers to test.
