ASR 1001 IOS upgrade issue
raut.pawan
Hi I am changing IOS of Cisco ASR 1001  from asr1001-universalk9.03.07.02.S.152-4.S2.bin
to asr1000rp1-adventerprisek9.03.04.02.S.151-3.S2.bin but everty time it boot up with old IOS universalk9.
Is it becaused of Licence issue.
Router#sh bootvar
BOOT variable = bootflash:asr1000rp1-adventerprisek9.03.04.02.S.151-3.S2.bin,12;bootflash:asr1001-universalk9.03.07.02.S.152-4.S2.bin,12;
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
License Level: advipservices
License Type: Permanent
Next reload license Level: advipservices
cisco ASR1001 (1RU) processor with 1155941K/6147K bytes of memory.
Processor board ID SSI1607042B
4 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
7741439K bytes of eUSB flash at bootflash:.
Leo Laohoo
You downloaded the wrong file.  The file you wanted to run has "rp1" but the original file doesn't.  You downloaded a file for a different model.  Your router is an ASR 1001 with fixed RP but you've downloaded a file for a different sub-model of ASR, like the 1002 or 1004.
Go here instead:  http://software.cisco.com/download/release.html?mdfid=282993672&softwareid=282046477&release=3.10.3S&relind=AVAILABLE&rellifecycle=ED&reltype=latest
in addition to that, it seems like a downgrade rather than upgrade. Once you have the correct image, you need to change the boot system command to use the new image and negate the old one, or add it (the old one back) after, to have backup image in case it fails.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
