Slow speed when connecting router and switch to cable modem
abernathy
Hello
I am fairly new to cisco gear.
I am getting extremely slow internet speeds when I try using my router and switch.
This is how I have it configured.
Cable modem is plugged into Gi0/0 of router (1941)
Switch (48Port 3560 PoE) is plugged into Gi0/1
Gi0/0 is set to pull an address from modem (DHCP)
Gi0/1 has an ip address of x.x.x.1 assigned to it
Router is acting as DHCP for network
Switch has one vlan x.x.x.3
I am also using an Air Port Extreme configured as an Wireless Access Point.
If I connect to the wireless or straight to a port on the switch I feel like I am back in the days of 56K modems.
If I go from the modem straight to a wireless router I get around 21 Down/12 Up
Thanks for you help
Mike
 Have you done following this on your cisco router
1) DHCP pool configured for LAN Subnet is defined with Proper DNS provided by your service provider
2) cisco router is configured with Proper PAT towards Gi0/0 with LAN subnets x.x.x.x/24 .
3)  Any traffic goes out from router must be NATED , if you dont want to do NATing .In this you case your modem must have reverse route of your LAN subnet x.x.x.x/24 pointing to WAN Interface IP address of your router
Share me IPconfig/all connecting directly to your modem & IP config/all directly connecting to LAN switch .
Sandy
Here is the config of the router.
Current configuration : 1571 bytes
version 15.2
hostname 1941RT
boot-start-marker
boot-end-marker
enable secret 4 /sZEgK86jBjVXzoruM2Z28WmHDqHI9MhmweSfguco3U
no aaa new-model
ip cef
ip dhcp excluded-address 172.20.20.1 172.20.20.20
ip dhcp pool DATA
 import all
 network 172.20.20.0 255.255.255.0
 default-router 172.20.20.1
 dns-server 75.75.75.75 75.75.75.76
no ipv6 cef
license udi pid CISCO1941/K9 sn FTX1726804V
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address dhcp
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0/1
 ip address 172.20.20.1 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat source list 101 interface GigabitEthernet0/0 overload
ip nat inside source list 101 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 98.224.43.228
access-list 101 permit ip any any
access-list 101 permit ip 172.20.20.0 0.0.0.255 any
control-plane
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 login
 transport input all
scheduler allocate 20000 1000
end
Output of ipconfig /all from PC when plugged into modem.
Windows IP Configuration
   Host Name . . . . . . . . . . . . : Mike-PC
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
   DNS Suffix Search List. . . . . . : hsd1.fl.comcast.net.
Ethernet adapter Local Area Connection:
   Connection-specific DNS Suffix  . : hsd1.fl.comcast.net.
   Description . . . . . . . . . . . : Broadcom NetXtreme 57xx Gigabit Controlle
r
   Physical Address. . . . . . . . . : 00-19-B9-75-72-6B
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
   IPv4 Address. . . . . . . . . . . : 67.190.198.114(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.248.0
   Lease Obtained. . . . . . . . . . : Wednesday, June 11, 2014 11:00:07 PM
   Lease Expires . . . . . . . . . . : Thursday, June 12, 2014 12:00:07 AM
   Default Gateway . . . . . . . . . : 67.190.192.1
   DHCP Server . . . . . . . . . . . : 76.96.92.132
   DNS Servers . . . . . . . . . . . : 75.75.75.75
                                       75.75.76.76
   NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter isatap.hsd1.fl.comcast.net.:
   Media State . . . . . . . . . . . : Media disconnected
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
   Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
   DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Teredo Tunneling Pseudo-Interface:
   Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
   IPv6 Address. . . . . . . . . . . : 2001:0:9d38:6abd:1019:2e4c:bc41:398d(Pref
erred)
   Link-local IPv6 Address . . . . . : fe80::1019:2e4c:bc41:398d%13(Preferred)
   NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter 6TO4 Adapter:
   Description . . . . . . . . . . . : Microsoft 6to4 Adapter
   IPv6 Address. . . . . . . . . . . : 2002:43be:c672::43be:c672(Preferred)
   Default Gateway . . . . . . . . . : 2002:c058:6301::
                                       75.75.76.76
