ASR 1001 software upgrade!!
Mohit Chauhan
Hi friends,
I am trying to upgrade the software on the ASR 1001 currently running
     IOS XE Version: 03.06.00.S
     Cisco IOS Software, IOS-XE
Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.2(2)S, RELEASE SOFTWARE (fc1)
I had downloaded the file
asr1001-universalk9.03.07.01.S.152-4.S1.bin
from the cisco website and uploaded on the router's bootflash.
Then I pointed the boot to this file by:
(conf t)# boot system flash asr1001-universalk9.03.07.01.S.152-4.S1.bin
also tried
(conf t)# boot system flash /asr1001-universalk9.03.07.01.S.152-4.S1.bin
but everytime it boots, it gives the following error while booting and finally boot up with the old image:
Initializing Hardware ...
Calculating the ROMMON CRC ... CRC is correct
System Bootstrap, Version 15.0(1r)S, RELEASE SOFTWARE
Copyright (c) 1994-2010 by cisco Systems, Inc.
Current image running: Boot ROM1
Last reset cause: Watchdog/ICH
ASR1000-1RU platform with 8388608 Kbytes of main memory
boot: unsupported boot device "/asr1001-universalk9.03.07.01.S.152-4.S1.bin"
autoboot: boot failed, restarting...
no valid BOOT image found
Final autoboot attempt from default boot device...
File size is 0x15af15c8
Located asr1001-universalk9.03.06.00.S.152-2.S.bin
Image size 363795912 inode num 12, bks cnt 88818 blk size 8*512
What could be the issue? Any Suggestions? I was looking in the website but it is mostly talking about the ISSU related upgrade which in my case is not required as i dont need to do this on a production router and also i am not runnig in sso mode.
Cheers,
Mohit
Remove your current boot statement and use like this
boot system flash bootflash:asr1001-universalk9.03.07.01.S.152-4.S1.bin
6 Replies 6
Raju Sekharan
Where is your image located on
disk0: or flash?
Can you get he following outputs
dir all
it seems bootflash to me.
here is the output:
Inet#dir all
Directory of system:/
    2  -r--           0                      default-running-config
    4  dr-x           0                      memory
    1  -rw-        9643                      running-config
    3  dr-x           0                      vfile
No space information available
Directory of tmpsys:/
    6  drw-           0                      eem_lib_system
    5  drw-           0                      eem_lib_user
   18  -rw-           0                      eem_pnt_0
   20  -rw-           0                      eem_pnt_1
   38  -rw-           0                      eem_pnt_10
   40  -rw-           0                      eem_pnt_11
   42  -rw-           0                      eem_pnt_12
   44  -rw-           0                      eem_pnt_13
   46  -rw-           0                      eem_pnt_14
   48  -rw-           0                      eem_pnt_15
   22  -rw-           0                      eem_pnt_2
   24  -rw-           0                      eem_pnt_3
   26  -rw-           0                      eem_pnt_4
   28  -rw-           0                      eem_pnt_5
   30  -rw-           0                      eem_pnt_6
   32  -rw-           0                      eem_pnt_7
   34  -rw-           0                      eem_pnt_8
   36  -rw-           0                      eem_pnt_9
    4  drw-           0                      eem_policy
    8  drw-           0                      eem_pub
   17  -rw-           0                      eem_rpc_0
   19  -rw-           0                      eem_rpc_1
   37  -rw-           0                      eem_rpc_10
   39  -rw-           0                      eem_rpc_11
   41  -rw-           0                      eem_rpc_12
   43  -rw-           0                      eem_rpc_13
   45  -rw-           0                      eem_rpc_14
   47  -rw-           0                      eem_rpc_15
   21  -rw-           0                      eem_rpc_2
   23  -rw-           0                      eem_rpc_3
   25  -rw-           0                      eem_rpc_4
   27  -rw-           0                      eem_rpc_5
   29  -rw-           0                      eem_rpc_6
   31  -rw-           0                      eem_rpc_7
   33  -rw-           0                      eem_rpc_8
   35  -rw-           0                      eem_rpc_9
    7  drw-           0                      eem_temp
    1  dr-x           0                      lib
    9  drw-           0                      macro_scripts
Directory of bootflash:/
   11  drwx       16384   Sep 2 2012 23:25:57 +08:00  lost+found
   12  -rw-   363795912   Sep 2 2012 23:28:04 +08:00  asr1001-universalk9.03.06.00.S.152-2.S.bin
225793  drwx        4096   Sep 2 2012 23:27:19 +08:00  .installer
129025  drwx        4096   Sep 2 2012 23:59:48 +08:00  core
516097  drwx        4096  Oct 10 2012 06:22:17 +08:00  .prst_sync
48385  drwx        4096   Sep 3 2012 00:00:13 +08:00  .rollback_timer
48386  -rw-           0   Sep 3 2012 00:00:33 +08:00  tracelogs.546
370945  drwx       12288  Oct 10 2012 07:57:29 +08:00  tracelogs
48387  -rw-   379513624  Oct 10 2012 06:04:48 +08:00  asr1001-universalk9.03.07.01.S.152-4.S1.bin
7802802176 bytes total (6661013504 bytes free)
Directory of nvram:/
32769  -rw-        9643                      startup-config
32770  ----          25                      private-config
32771  -rw-        9643                      underlying-config
    1  ----          88                      persistent-data
    2  -rw-          17                      ecfm_ieee_mib
    3  -rw-           0                      ifIndex-table
33554432 bytes total (33541640 bytes free)
Hi there,
I cant believe it that was missing. yea, it actually worked well, but while you are here, could i ask you this simple Q (probably for you), once i have got this upgraded to  higher version, i dont see a point keeping the old version on the flash.
But when i do
sho flash all
i see so many files, whats the best way to delete the unwanted files from here?
i'll also open a new question thread for running sso mode on this router so if you can help there that would be terrific.
this is below output now that i see:
Inet#sh flash all
-#- --length-- ---------date/time--------- path
  1       4096 Oct 10 2012 09:27:22 +00:00 /bootflash/
  2      16384 Sep 02 2012 23:25:57 +00:00 /bootflash/lost+found
  3  363795912 Sep 02 2012 23:28:04 +00:00 /bootflash/asr1001-universalk9.03.06.00.S.152-2.S.bin
  4       4096 Sep 02 2012 23:27:19 +00:00 /bootflash/.installer
  5       4096 Sep 02 2012 23:59:48 +00:00 /bootflash/core
  6       4096 Oct 10 2012 09:02:31 +00:00 /bootflash/.prst_sync
  7       4096 Sep 03 2012 00:00:13 +00:00 /bootflash/.rollback_timer
  8          0 Sep 03 2012 00:00:33 +00:00 /bootflash/tracelogs.546
  9      12288 Oct 10 2012 09:30:48 +00:00 /bootflash/tracelogs
10        479 Oct 10 2012 04:54:59 +00:00 /bootflash/tracelogs/clientlib-26814_R0-0.log
11        940 Oct 10 2012 09:27:22 +00:00 /bootflash/tracelogs/inst_cleanup_R0-0.log
12        451 Oct 10 2012 09:22:21 +00:00 /bootflash/tracelogs/inst_cleanup_R0-0.log.24921.20121010092221
13        169 Oct 10 2012 09:02:08 +00:00 /bootflash/tracelogs/inst_compmatrix_R0-0.log
14        169 Oct 10 2012 09:01:57 +00:00 /bootflash/tracelogs/inst_publish_retrieve_sw_sets_R0-0.log
15        169 Oct 10 2012 09:01:57 +00:00 /bootflash/tracelogs/inst_rollback_timer_R0-0.log
16        531 Oct 10 2012 04:55:09 +00:00 /bootflash/tracelogs/cman_fp_F0-0.log.16887.20121009205508
17        260 Oct 10 2012 04:55:08 +00:00 /bootflash/tracelogs/btrace_rotate_sh_R0-0.log.23954.20121009205508
18        428 Oct 10 2012 04:55:14 +00:00 /bootflash/tracelogs/cmcc_0-0.log.16695.20121009205514
19        259 Oct 10 2012 04:55:13 +00:00 /bootflash/tracelogs/btrace_rotate_sh_R0-0.log.1399.20121009205513
20         74 Oct 10 2012 09:01:31 +00:00 /bootflash/tracelogs/binos_log_R0-0.log
21         74 Oct 10 2012 09:02:39 +00:00 /bootflash/tracelogs/inst_issu_switchover_R0-0.log
22       3627 Oct 10 2012 09:02:12 +00:00 /bootflash/tracelogs/inst_tdlresolve_R0-0.log
23        451 Oct 10 2012 09:12:20 +00:00 /bootflash/tracelogs/inst_cleanup_R0-0.log.19394.20121010091220
24        451 Oct 10 2012 09:17:21 +00:00 /bootflash/tracelogs/inst_cleanup_R0-0.log.21985.20121010091721
25        169 Oct 10 2012 09:02:44 +00:00 /bootflash/tracelogs/cfgwr-10958_R0-0.log
26        451 Oct 10 2012 09:27:22 +00:00 /bootflash/tracelogs/inst_cleanup_R0-0.log.27545.20121010092722
27        451 Oct 10 2012 07:32:18 +00:00 /bootflash/tracelogs/inst_cleanup_R0-0.log.16092.20121010073218
28        451 Oct 10 2012 07:37:20 +00:00 /bootflash/tracelogs/inst_cleanup_R0-0.log.19205.20121010073720
29        451 Oct 10 2012 07:42:21 +00:00 /bootflash/tracelogs/inst_cleanup_R0-0.log.21774.20121010074221
30        451 Oct 10 2012 07:47:23 +00:00 /bootflash/tracelogs/inst_cleanup_R0-0.log.25138.20121010074723
31        451 Oct 10 2012 07:52:24 +00:00 /bootflash/tracelogs/inst_cleanup_R0-0.log.27583.20121010075224
32        451 Oct 10 2012 07:57:26 +00:00 /bootflash/tracelogs/inst_cleanup_R0-0.log.30699.20121010075726
33        449 Oct 10 2012 08:02:28 +00:00 /bootflash/tracelogs/inst_cleanup_R0-0.log.856.20121010080228
34        450 Oct 10 2012 08:12:30 +00:00 /bootflash/tracelogs/inst_cleanup_R0-0.log.6659.20121010081230
35       1195 Oct 10 2012 05:46:51 +00:00 /bootflash/tracelogs/pkg_summary_28626_R0-0.log
36        450 Oct 10 2012 08:17:31 +00:00 /bootflash/tracelogs/inst_cleanup_R0-0.log.9305.20121010081731
37        451 Oct 10 2012 08:22:33 +00:00 /bootflash/tracelogs/inst_cleanup_R0-0.log.12358.20121010082233
38        451 Oct 10 2012 08:27:35 +00:00 /bootflash/tracelogs/inst_cleanup_R0-0.log.14990.20121010082735
39        451 Oct 10 2012 08:32:37 +00:00 /bootflash/tracelogs/inst_cleanup_R0-0.log.18057.20121010083237
40       2941 Oct 10 2012 06:06:38 +00:00 /bootflash/tracelogs/IOSRP_R0-0.log.26983.20121009220638
41        210 Oct 10 2012 06:06:38 +00:00 /bootflash/tracelogs/btrace_rotate_sh_R0-0.log.7428.20121009220638
42       4958 Oct 10 2012 06:06:38 +00:00 /bootflash/tracelogs/btrace_rotate_sh_pmanlog_R0-0.log.23338.20121009220638
43        194 Oct 10 2012 06:06:38 +00:00 /bootflash/tracelogs/chasync_R0-0.log.8427.20121009220638
44      31067 Oct 10 2012 06:06:39 +00:00 /bootflash/tracelogs/cmand_R0-0.log.23847.20121009220639
45       4072 Oct 10 2012 06:06:39 +00:00 /bootflash/tracelogs/cmand_pmanlog_R0-0.log.23555.20121009220639
46      28264 Oct 10 2012 06:06:39 +00:00 /bootflash/tracelogs/droputil_14836_R0-0.log.16547.20121009220639
47       1391 Oct 10 2012 06:06:39 +00:00 /bootflash/tracelogs/emd_R0-0.log.24173.20121009220639
48       3972 Oct 10 2012 06:06:39 +00:00 /bootflash/tracelogs/emd_pmanlog_R0-0.log.23883.20121009220639
49       1315 Oct 10 2012 06:06:39 +00:00 /bootflash/tracelogs/fman_rp_R0-0.log.24873.20121009220639
50       4178 Oct 10 2012 06:06:39 +00:00 /bootflash/tracelogs/fman_rp_pmanlog_R0-0.log.24193.20121009220639
51       2317 Oct 10 2012 06:06:39 +00:00 /bootflash/tracelogs/hman_R0-0.log.25336.20121009220639
52      37353 Oct 10 2012 06:06:39 +00:00 /bootflash/tracelogs/hman_pmanlog_R0-0.log.24599.20121009220639
53       1073 Oct 10 2012 06:06:39 +00:00 /bootflash/tracelogs/imand_R0-0.log.25735.20121009220639
54       4072 Oct 10 2012 06:06:39 +00:00 /bootflash/tracelogs/imand_pmanlog_R0-0.log.24848.20121009220639
55        115 Oct 10 2012 06:06:39 +00:00 /bootflash/tracelogs/inst_rollback_timer_R0-0.log.8311.20121009220639
56        115 Oct 10 2012 06:06:39 +00:00 /bootflash/tracelogs/iptbl_R0-0.log.8542.20121009220639
57       2623 Oct 10 2012 06:06:39 +00:00 /bootflash/tracelogs/licensed_R0-0.log.26161.20121009220639
58       4567 Oct 10 2012 06:06:39 +00:00 /bootflash/tracelogs/licensed_pmanlog_R0-0.log.25566.20121009220639
59      17104 Oct 10 2012 06:06:39 +00:00 /bootflash/tracelogs/linux_iosd_image_pmanlog_R0-0.log.26142.20121009220639
60       2737 Oct 10 2012 06:06:39 +00:00 /bootflash/tracelogs/lman_R0-0.log.28799.20121009220639
61       4022 Oct 10 2012 06:06:39 +00:00 /bootflash/tracelogs/lman_pmanlog_R0-0.log.26590.20121009220640
62        115 Oct 10 2012 06:06:40 +00:00 /bootflash/tracelogs/oom_R0-0.log.8567.20121009220640
63       9570 Oct 10 2012 06:06:40 +00:00 /bootflash/tracelogs/pcscd_service_sh_pmanlog_R0-0.log.26717.20121009220640
64        211 Oct 10 2012 06:06:40 +00:00 /bootflash/tracelogs/periodic_R0-0.log.29005.20121009220640
65       4336 Oct 10 2012 06:06:40 +00:00 /bootflash/tracelogs/periodic_sh_pmanlog_R0-0.log.27160.20121009220640
66      16950 Oct 10 2012 06:06:40 +00:00 /bootflash/tracelogs/plogd_R0-0.log.28271.20121009220640
67       4072 Oct 10 2012 06:06:40 +00:00 /bootflash/tracelogs/plogd_pmanlog_R0-0.log.27333.20121009220640
68       1122 Oct 10 2012 06:06:40 +00:00 /bootflash/tracelogs/psd_R0-0.log.28207.20121009220640
69       4137 Oct 10 2012 06:06:40 +00:00 /bootflash/tracelogs/psd_pmanlog_R0-0.log.27574.20121009220640
70       1842 Oct 10 2012 06:06:40 +00:00 /bootflash/tracelogs/psvp_R0-0.log.22930.20121009220640
71      13571 Oct 10 2012 06:06:40 +00:00 /bootflash/tracelogs/pvp_R0-0.log.22988.20121009220640
72      42054 Oct 10 2012 06:06:40 +00:00 /bootflash/tracelogs/reflector_14829_R0-0.log.16581.20121009220640
73       6083 Oct 10 2012 06:06:40 +00:00 /bootflash/tracelogs/smand_R0-0.log.28933.20121009220640
74       4438 Oct 10 2012 06:06:40 +00:00 /bootflash/tracelogs/smand_pmanlog_R0-0.log.28151.20121009220640
75       4886 Oct 10 2012 06:06:40 +00:00 /bootflash/tracelogs/sort_files_by_inode_sh_pmanlog_R0-0.log.28828.20121009220640
76       6685 Oct 10 2012 06:06:40 +00:00 /bootflash/tracelogs/vman_R0-0.log.30656.20121009220640
77       4780 Oct 10 2012 06:06:40 +00:00 /bootflash/tracelogs/vman_pmanlog_R0-0.log.29705.20121009220640
78        252 Oct 10 2012 06:06:40 +00:00 /bootflash/tracelogs/btrace_rotate_sh_R0-0.log.7428.20121009220640
79        236 Oct 10 2012 06:06:41 +00:00 /bootflash/tracelogs/chasync_R0-0.log.8427.20121009220641
80      28306 Oct 10 2012 06:06:41 +00:00 /bootflash/tracelogs/droputil_14836_R0-0.log.16547.20121009220641
81        157 Oct 10 2012 06:06:41 +00:00 /bootflash/tracelogs/inst_rollback_timer_R0-0.log.8311.20121009220641
82        157 Oct 10 2012 06:06:41 +00:00 /bootflash/tracelogs/iptbl_R0-0.log.8542.20121009220641
83       1015 Oct 10 2012 06:06:41 +00:00 /bootflash/tracelogs/license.licensed.9999.20121009220641
84        157 Oct 10 2012 06:06:41 +00:00 /bootflash/tracelogs/oom_R0-0.log.8567.20121009220641
85       1884 Oct 10 2012 06:06:41 +00:00 /bootflash/tracelogs/psvp_R0-0.log.22930.20121009220641
86      42096 Oct 10 2012 06:06:41 +00:00 /bootflash/tracelogs/reflector_14829_R0-0.log.16581.20121009220641
87      46634 Oct 10 2012 06:06:54 +00:00 /bootflash/tracelogs/inst_implode_dmesg.20121009220654
88        169 Oct 10 2012 04:54:46 +00:00 /bootflash/tracelogs/inst_issu_check_20930_R0-0.log
89        169 Oct 10 2012 06:21:44 +00:00 /bootflash/tracelogs/inst_issu_check_20988_R0-0.log
90       4194 Oct 10 2012 04:54:56 +00:00 /bootflash/tracelogs/cmand_R0-0.log.16447.20121009205456
91        450 Oct 10 2012 04:54:56 +00:00 /bootflash/tracelogs/inst_tdlresolve_R0-0.log.21706.20121009205456
92        479 Oct 10 2012 06:10:08 +00:00 /bootflash/tracelogs/clientlib-26879_R0-0.log
93        169 Oct 10 2012 06:09:55 +00:00 /bootflash/tracelogs/inst_issu_check_20932_R0-0.log
94        169 Oct 10 2012 06:09:55 +00:00 /bootflash/tracelogs/inst_issu_check_20989_R0-0.log
95       4194 Oct 10 2012 06:10:05 +00:00 /bootflash/tracelogs/cmand_R0-0.log.16450.20121009221005
96        451 Oct 10 2012 08:37:39 +00:00 /bootflash/tracelogs/inst_cleanup_R0-0.log.20884.20121010083739
97        450 Oct 10 2012 06:10:04 +00:00 /bootflash/tracelogs/inst_tdlresolve_R0-0.log.21706.20121009221004
98        531 Oct 10 2012 06:10:19 +00:00 /bootflash/tracelogs/cman_fp_F0-0.log.16932.20121009221017
99        260 Oct 10 2012 06:10:17 +00:00 /bootflash/tracelogs/btrace_rotate_sh_R0-0.log.25692.20121009221017
100        428 Oct 10 2012 06:10:24 +00:00 /bootflash/tracelogs/cmcc_0-0.log.16772.20121009221023
101        259 Oct 10 2012 06:10:23 +00:00 /bootflash/tracelogs/btrace_rotate_sh_R0-0.log.1883.20121009221023
102        168 Oct 10 2012 06:10:33 +00:00 /bootflash/tracelogs/cfgwr-9238_R0-0.log
103        168 Oct 10 2012 06:10:33 +00:00 /bootflash/tracelogs/cfgwr-9259_R0-0.log
104        168 Oct 10 2012 06:10:33 +00:00 /bootflash/tracelogs/cfgwr-9261_R0-0.log
105        168 Oct 10 2012 06:10:33 +00:00 /bootflash/tracelogs/cfgwr-9265_R0-0.log
106        168 Oct 10 2012 06:10:33 +00:00 /bootflash/tracelogs/cfgwr-9266_R0-0.log
107        168 Oct 10 2012 06:10:33 +00:00 /bootflash/tracelogs/cfgwr-9267_R0-0.log
108        168 Oct 10 2012 06:10:33 +00:00 /bootflash/tracelogs/cfgwr-9268_R0-0.log
109        451 Oct 10 2012 08:42:41 +00:00 /bootflash/tracelogs/inst_cleanup_R0-0.log.23802.20121010084241
110       2941 Oct 10 2012 06:17:29 +00:00 /bootflash/tracelogs/IOSRP_R0-0.log.26951.20121009221729
111        211 Oct 10 2012 06:17:29 +00:00 /bootflash/tracelogs/btrace_rotate_sh_R0-0.log.13178.20121009221729
112       4958 Oct 10 2012 06:17:29 +00:00 /bootflash/tracelogs/btrace_rotate_sh_pmanlog_R0-0.log.23590.20121009221729
113        194 Oct 10 2012 06:17:29 +00:00 /bootflash/tracelogs/chasync_R0-0.log.8531.20121009221729
114      31188 Oct 10 2012 06:17:29 +00:00 /bootflash/tracelogs/cmand_R0-0.log.24187.20121009221729
115       4072 Oct 10 2012 06:17:29 +00:00 /bootflash/tracelogs/cmand_pmanlog_R0-0.log.23701.20121009221729
116      28052 Oct 10 2012 06:17:29 +00:00 /bootflash/tracelogs/droputil_14829_R0-0.log.16611.20121009221729
117       1227 Oct 10 2012 06:17:29 +00:00 /bootflash/tracelogs/emd_R0-0.log.25099.20121009221729
118       3972 Oct 10 2012 06:17:29 +00:00 /bootflash/tracelogs/emd_pmanlog_R0-0.log.23926.20121009221729
119       1608 Oct 10 2012 06:17:29 +00:00 /bootflash/tracelogs/fman_rp_R0-0.log.25140.20121009221729
120       4178 Oct 10 2012 06:17:29 +00:00 /bootflash/tracelogs/fman_rp_pmanlog_R0-0.log.24159.20121009221729
121       2028 Oct 10 2012 06:17:29 +00:00 /bootflash/tracelogs/hman_R0-0.log.25273.20121009221729
122       4028 Oct 10 2012 06:17:29 +00:00 /bootflash/tracelogs/hman_pmanlog_R0-0.log.24402.20121009221729
123       1288 Oct 10 2012 06:17:29 +00:00 /bootflash/tracelogs/imand_R0-0.log.25747.20121009221729
124       4072 Oct 10 2012 06:17:29 +00:00 /bootflash/tracelogs/imand_pmanlog_R0-0.log.24707.20121009221729
125        115 Oct 10 2012 06:17:29 +00:00 /bootflash/tracelogs/inst_rollback_timer_R0-0.log.8318.20121009221729
126        115 Oct 10 2012 06:17:30 +00:00 /bootflash/tracelogs/iptbl_R0-0.log.8449.20121009221730
127       2623 Oct 10 2012 06:17:30 +00:00 /bootflash/tracelogs/licensed_R0-0.log.26466.20121009221730
128       4567 Oct 10 2012 06:17:30 +00:00 /bootflash/tracelogs/licensed_pmanlog_R0-0.log.25765.20121009221730
129      15177 Oct 10 2012 06:17:30 +00:00 /bootflash/tracelogs/linux_iosd_image_pmanlog_R0-0.log.26080.20121009221730
130       2737 Oct 10 2012 06:17:30 +00:00 /bootflash/tracelogs/lman_R0-0.log.27285.20121009221730
131       4022 Oct 10 2012 06:17:30 +00:00 /bootflash/tracelogs/lman_pmanlog_R0-0.log.26330.20121009221730
132        115 Oct 10 2012 06:17:30 +00:00 /bootflash/tracelogs/oom_R0-0.log.8451.20121009221730
133       9570 Oct 10 2012 06:17:30 +00:00 /bootflash/tracelogs/pcscd_service_sh_pmanlog_R0-0.log.27128.20121009221730
134        211 Oct 10 2012 06:17:30 +00:00 /bootflash/tracelogs/periodic_R0-0.log.28230.20121009221730
135       4336 Oct 10 2012 06:17:30 +00:00 /bootflash/tracelogs/periodic_sh_pmanlog_R0-0.log.27264.20121009221730
136      16950 Oct 10 2012 06:17:30 +00:00 /bootflash/tracelogs/plogd_R0-0.log.28493.20121009221730
137       4072 Oct 10 2012 06:17:30 +00:00 /bootflash/tracelogs/plogd_pmanlog_R0-0.log.27709.20121009221730
138        960 Oct 10 2012 06:17:30 +00:00 /bootflash/tracelogs/psd_R0-0.log.28851.20121009221730
139       4137 Oct 10 2012 06:17:30 +00:00 /bootflash/tracelogs/psd_pmanlog_R0-0.log.28490.20121009221730
140       1842 Oct 10 2012 06:17:30 +00:00 /bootflash/tracelogs/psvp_R0-0.log.22930.20121009221730
141      13571 Oct 10 2012 06:17:30 +00:00 /bootflash/tracelogs/pvp_R0-0.log.22988.20121009221730
142      36950 Oct 10 2012 06:17:31 +00:00 /bootflash/tracelogs/reflector_14824_R0-0.log.16551.20121009221731
143       5887 Oct 10 2012 06:17:31 +00:00 /bootflash/tracelogs/smand_R0-0.log.29629.20121009221731
144       4438 Oct 10 2012 06:17:31 +00:00 /bootflash/tracelogs/smand_pmanlog_R0-0.log.29056.20121009221731
145       4886 Oct 10 2012 06:17:31 +00:00 /bootflash/tracelogs/sort_files_by_inode_sh_pmanlog_R0-0.log.29677.20121009221731
146       6685 Oct 10 2012 06:17:31 +00:00 /bootflash/tracelogs/vman_R0-0.log.31124.20121009221731
147       4780 Oct 10 2012 06:17:31 +00:00 /bootflash/tracelogs/vman_pmanlog_R0-0.log.30233.20121009221731
148        253 Oct 10 2012 06:17:31 +00:00 /bootflash/tracelogs/btrace_rotate_sh_R0-0.log.13178.20121009221731
149        236 Oct 10 2012 06:17:31 +00:00 /bootflash/tracelogs/chasync_R0-0.log.8531.20121009221731
150      28094 Oct 10 2012 06:17:31 +00:00 /bootflash/tracelogs/droputil_14829_R0-0.log.16611.20121009221731
151        157 Oct 10 2012 06:17:31 +00:00 /bootflash/tracelogs/inst_rollback_timer_R0-0.log.8318.20121009221731
152        157 Oct 10 2012 06:17:31 +00:00 /bootflash/tracelogs/iptbl_R0-0.log.8449.20121009221731
153       1015 Oct 10 2012 06:17:31 +00:00 /bootflash/tracelogs/license.licensed.9999.20121009221731
154        157 Oct 10 2012 06:17:31 +00:00 /bootflash/tracelogs/oom_R0-0.log.8451.20121009221731
155       1884 Oct 10 2012 06:17:31 +00:00 /bootflash/tracelogs/psvp_R0-0.log.22930.20121009221731
156      46640 Oct 10 2012 06:17:44 +00:00 /bootflash/tracelogs/inst_implode_dmesg.20121009221744
157        479 Oct 10 2012 06:21:57 +00:00 /bootflash/tracelogs/clientlib-27813_R0-0.log
158        169 Oct 10 2012 06:21:44 +00:00 /bootflash/tracelogs/inst_issu_check_20931_R0-0.log
159       4194 Oct 10 2012 06:21:54 +00:00 /bootflash/tracelogs/cmand_R0-0.log.16449.20121009222154
160        451 Oct 10 2012 08:47:41 +00:00 /bootflash/tracelogs/inst_cleanup_R0-0.log.26465.20121010084741
161        450 Oct 10 2012 06:21:58 +00:00 /bootflash/tracelogs/inst_tdlresolve_R0-0.log.21706.20121009222158
162        260 Oct 10 2012 06:22:07 +00:00 /bootflash/tracelogs/btrace_rotate_sh_R0-0.log.24173.20121009222207
163        428 Oct 10 2012 06:22:12 +00:00 /bootflash/tracelogs/cmcc_0-0.log.16770.20121009222211
164        259 Oct 10 2012 06:22:11 +00:00 /bootflash/tracelogs/btrace_rotate_sh_R0-0.log.1595.20121009222211
165        168 Oct 10 2012 06:22:21 +00:00 /bootflash/tracelogs/cfgwr-9176_R0-0.log
166        168 Oct 10 2012 06:22:21 +00:00 /bootflash/tracelogs/cfgwr-9189_R0-0.log
167        168 Oct 10 2012 06:22:21 +00:00 /bootflash/tracelogs/cfgwr-9191_R0-0.log
168        168 Oct 10 2012 06:22:21 +00:00 /bootflash/tracelogs/cfgwr-9193_R0-0.log
169        168 Oct 10 2012 06:22:21 +00:00 /bootflash/tracelogs/cfgwr-9200_R0-0.log
170        168 Oct 10 2012 06:22:21 +00:00 /bootflash/tracelogs/cfgwr-9209_R0-0.log
171        168 Oct 10 2012 06:22:21 +00:00 /bootflash/tracelogs/cfgwr-9215_R0-0.log
172        168 Oct 10 2012 06:22:21 +00:00 /bootflash/tracelogs/cfgwr-9220_R0-0.log
173        531 Oct 10 2012 06:23:09 +00:00 /bootflash/tracelogs/cman_fp_F0-0.log.16930.20121009222206
174        451 Oct 10 2012 08:52:43 +00:00 /bootflash/tracelogs/inst_cleanup_R0-0.log.29598.20121010085243
175        451 Oct 10 2012 08:57:45 +00:00 /bootflash/tracelogs/inst_cleanup_R0-0.log.32217.20121010085745
176        169 Oct 10 2012 06:36:39 +00:00 /bootflash/tracelogs/cfgwr-17223_R0-0.log
177        169 Oct 10 2012 06:36:39 +00:00 /bootflash/tracelogs/cfgwr-17224_R0-0.log
178        194 Oct 10 2012 08:59:30 +00:00 /bootflash/tracelogs/chasync_R0-0.log.8565.20121010085930
179        623 Oct 10 2012 09:02:13 +00:00 /bootflash/tracelogs/clientlib-28089_R0-0.log
180        450 Oct 10 2012 08:07:29 +00:00 /bootflash/tracelogs/inst_cleanup_R0-0.log.3528.20121010080729
181        210 Oct 10 2012 08:59:30 +00:00 /bootflash/tracelogs/btrace_rotate_sh_R0-0.log.1853.20121010085930
182       4739 Oct 10 2012 08:59:30 +00:00 /bootflash/tracelogs/btrace_rotate_sh_pmanlog_R0-0.log.23347.20121010085930
183      32524 Oct 10 2012 08:59:30 +00:00 /bootflash/tracelogs/droputil_14846_R0-0.log.16609.20121010085930
184       1395 Oct 10 2012 08:59:30 +00:00 /bootflash/tracelogs/emd_R0-0.log.24394.20121010085930
185       3972 Oct 10 2012 08:59:30 +00:00 /bootflash/tracelogs/emd_pmanlog_R0-0.log.23804.20121010085930
186       1315 Oct 10 2012 08:59:30 +00:00 /bootflash/tracelogs/fman_rp_R0-0.log.24563.20121010085930
187       4178 Oct 10 2012 08:59:30 +00:00 /bootflash/tracelogs/fman_rp_pmanlog_R0-0.log.24174.20121010085930
188       2978 Oct 10 2012 08:59:30 +00:00 /bootflash/tracelogs/hman_R0-0.log.25759.20121010085930
189       4028 Oct 10 2012 08:59:30 +00:00 /bootflash/tracelogs/hman_pmanlog_R0-0.log.24448.20121010085930
190       2711 Oct 10 2012 08:59:30 +00:00 /bootflash/tracelogs/imand_R0-0.log.24935.20121010085930
191       4072 Oct 10 2012 08:59:30 +00:00 /bootflash/tracelogs/imand_pmanlog_R0-0.log.24659.20121010085930
192        115 Oct 10 2012 08:59:30 +00:00 /bootflash/tracelogs/inst_rollback_timer_R0-0.log.8410.20121010085930
193        115 Oct 10 2012 08:59:30 +00:00 /bootflash/tracelogs/iptbl_R0-0.log.8626.20121010085930
194       4567 Oct 10 2012 08:59:30 +00:00 /bootflash/tracelogs/licensed_pmanlog_R0-0.log.25015.20121010085930
195      15354 Oct 10 2012 08:59:30 +00:00 /bootflash/tracelogs/linux_iosd_image_pmanlog_R0-0.log.25606.20121010085930
196       2591 Oct 10 2012 08:59:31 +00:00 /bootflash/tracelogs/lman_R0-0.log.28066.20121010085931
197       4022 Oct 10 2012 08:59:31 +00:00 /bootflash/tracelogs/lman_pmanlog_R0-0.log.25667.20121010085931
198        115 Oct 10 2012 08:59:31 +00:00 /bootflash/tracelogs/oom_R0-0.log.8524.20121010085931
199       9570 Oct 10 2012 08:59:31 +00:00 /bootflash/tracelogs/pcscd_service_sh_pmanlog_R0-0.log.25844.20121010085931
200        211 Oct 10 2012 08:59:31 +00:00 /bootflash/tracelogs/periodic_R0-0.log.26833.20121010085931
201       4479 Oct 10 2012 08:59:31 +00:00 /bootflash/tracelogs/periodic_sh_pmanlog_R0-0.log.26139.20121010085931
202      17550 Oct 10 2012 08:59:31 +00:00 /bootflash/tracelogs/plogd_R0-0.log.27168.20121010085931
203       4072 Oct 10 2012 08:59:31 +00:00 /bootflash/tracelogs/plogd_pmanlog_R0-0.log.26441.20121010085931
204        960 Oct 10 2012 08:59:31 +00:00 /bootflash/tracelogs/psd_R0-0.log.27577.20121010085931
205       4137 Oct 10 2012 08:59:31 +00:00 /bootflash/tracelogs/psd_pmanlog_R0-0.log.26573.20121010085931
206       1842 Oct 10 2012 08:59:31 +00:00 /bootflash/tracelogs/psvp_R0-0.log.22929.20121010085931
207      13571 Oct 10 2012 08:59:31 +00:00 /bootflash/tracelogs/pvp_R0-0.log.22989.20121010085931
208      55545 Oct 10 2012 08:59:31 +00:00 /bootflash/tracelogs/reflector_14845_R0-0.log.16549.20121010085931
209       5299 Oct 10 2012 08:59:31 +00:00 /bootflash/tracelogs/smand_R0-0.log.29372.20121010085931
210       4438 Oct 10 2012 08:59:31 +00:00 /bootflash/tracelogs/smand_pmanlog_R0-0.log.27228.20121010085931
211       5481 Oct 10 2012 08:59:31 +00:00 /bootflash/tracelogs/sort_files_by_inode_sh_pmanlog_R0-0.log.27410.20121010085931
212       7736 Oct 10 2012 08:59:31 +00:00 /bootflash/tracelogs/vman_R0-0.log.28919.20121010085931
213       4958 Oct 10 2012 08:59:31 +00:00 /bootflash/tracelogs/vman_pmanlog_R0-0.log.28289.20121010085931
214        252 Oct 10 2012 08:59:32 +00:00 /bootflash/tracelogs/btrace_rotate_sh_R0-0.log.1853.20121010085932
215        236 Oct 10 2012 08:59:32 +00:00 /bootflash/tracelogs/chasync_R0-0.log.8565.20121010085932
216      32566 Oct 10 2012 08:59:32 +00:00 /bootflash/tracelogs/droputil_14846_R0-0.log.16609.20121010085932
217        157 Oct 10 2012 08:59:32 +00:00 /bootflash/tracelogs/inst_rollback_timer_R0-0.log.8410.20121010085932
218        157 Oct 10 2012 08:59:32 +00:00 /bootflash/tracelogs/iptbl_R0-0.log.8626.20121010085932
219       1015 Oct 10 2012 08:59:32 +00:00 /bootflash/tracelogs/license.licensed.9999.20121010085932
220        157 Oct 10 2012 08:59:32 +00:00 /bootflash/tracelogs/oom_R0-0.log.8524.20121010085932
221       1884 Oct 10 2012 08:59:32 +00:00 /bootflash/tracelogs/psvp_R0-0.log.22929.20121010085932
222      55587 Oct 10 2012 08:59:32 +00:00 /bootflash/tracelogs/reflector_14845_R0-0.log.16549.20121010085932
223      46749 Oct 10 2012 08:59:44 +00:00 /bootflash/tracelogs/inst_implode_dmesg.20121010085944
224        169 Oct 10 2012 09:02:02 +00:00 /bootflash/tracelogs/inst_issu_check_22204_R0-0.log
225        169 Oct 10 2012 09:02:02 +00:00 /bootflash/tracelogs/inst_issu_check_22262_R0-0.log
226       4196 Oct 10 2012 09:02:10 +00:00 /bootflash/tracelogs/cmand_R0-0.log.17673.20121010010210
227       3908 Oct 10 2012 09:02:10 +00:00 /bootflash/tracelogs/inst_tdlresolve_R0-0.log.22980.20121010010210
228        479 Oct 10 2012 09:02:15 +00:00 /bootflash/tracelogs/clientlib-31136_R0-0.log
229        451 Oct 10 2012 09:02:16 +00:00 /bootflash/tracelogs/inst_cleanup_R0-0.log.30301.20121010010216
230        531 Oct 10 2012 09:02:23 +00:00 /bootflash/tracelogs/cman_fp_F0-0.log.18157.20121010010223
231        260 Oct 10 2012 09:02:22 +00:00 /bootflash/tracelogs/btrace_rotate_sh_R0-0.log.25485.20121010010222
232        259 Oct 10 2012 09:02:28 +00:00 /bootflash/tracelogs/btrace_rotate_sh_R0-0.log.1748.20121010010228
233        169 Oct 10 2012 09:02:44 +00:00 /bootflash/tracelogs/cfgwr-10959_R0-0.log
234        169 Oct 10 2012 09:02:45 +00:00 /bootflash/tracelogs/cfgwr-10960_R0-0.log
235        169 Oct 10 2012 09:02:45 +00:00 /bootflash/tracelogs/cfgwr-10961_R0-0.log
236        169 Oct 10 2012 09:02:45 +00:00 /bootflash/tracelogs/cfgwr-10962_R0-0.log
237        169 Oct 10 2012 09:02:45 +00:00 /bootflash/tracelogs/cfgwr-10963_R0-0.log
238        169 Oct 10 2012 09:02:45 +00:00 /bootflash/tracelogs/cfgwr-10964_R0-0.log
239        169 Oct 10 2012 09:02:45 +00:00 /bootflash/tracelogs/cfgwr-10965_R0-0.log
240        451 Oct 10 2012 09:07:19 +00:00 /bootflash/tracelogs/inst_cleanup_R0-0.log.13451.20121010090719
241        428 Oct 10 2012 09:07:30 +00:00 /bootflash/tracelogs/cmcc_0-0.log.17996.20121010010228
242       1195 Oct 10 2012 09:07:50 +00:00 /bootflash/tracelogs/pkg_summary_14019_R0-0.log
243  379513624 Oct 10 2012 06:04:48 +00:00 /bootflash/asr1001-universalk9.03.07.01.S.152-4.S1.bin
244       4096 Oct 10 2012 09:02:20 +00:00 /bootflash/vman_fdb
6660476928 bytes available (745967616 bytes used)
Filesystem: bootflash
Filesystem Path: /bootflash
Filesystem Type: ext2
Mounted: Read/Write
You can delete it after going to that directory
cd bootflash:/tracelogs
delete inst_cleanup_R0-0*
For cleanup operations you can refer the below link
http://www.cisco.com/en/US/docs/routers/asr1000/operations/guide/performing_file_system_cleanups.html#wp1055979
I found that the only way is like this boot system
i.e leave out the flash as if you check the image in use with the word flash used it will still be on an older image.
