IR809 Router - Sys LED Amber, Blinking
pbelletty
I have an IR809 router and the SYS led is amber, blinking.
Any idea what this means?
Cheers,
Phil
pbelletty
Just found the answer - see below
By definition, amber blinking means the system has an error, but has network connectivity. For most of the time, this amber blinking condition is seen because one or more of the Ethernet ports on your IR829 is in administrative un-shut state, but there’s no actual link (e.g. cable disconnected or peer port is down etc.)
Julio E. Moisa
If the led related to the Sys (system) is blinking in amber, it could indicate a failure, it could be related to the power supply. It will receive energy but something related to hardware is not working properly.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
