ASR 1001 voice command issue
kingvoice
Hello  Experts;
                     I am unable to configure  ASR 1001 with voice configurations for SIP . There is no voice commands are showing  under configuration terminal
Any help would be higly apreciated
KV
6 Replies 6
Philip D'Ath
Are you running 3.7S or later?
Cisco IOS XE Software, Version 03.16.01a.S - Extended Support Release
Cisco IOS Software, ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S1a, RELEASE SOFTWARE (fc1)
Philip D'Ath
Which licence(s) have you got?
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
Which actual voice command where you trying to use?  I'm thinking you might need an "IP Services" licence.
Adel Barashed
Hello
I think you need to have UC license for the box as IP base will not cover that. Also check the module for SIP
