ASR 1001 X- Crypto Issue
Hello All,
Crypto feature is not coming up on the ASR... ON the data sheet its says that the feature is enable.. but its not coming up :(
Router#sh ver
Cisco IOS XE Software, Version 03.13.02.S - Extended Support Release
Cisco IOS Software, ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSAL-M), Version 15.4(3)S2, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Fri 30-Jan-15 14:23 by mcpre
Kindly Help,
Yeshwanth
9 Replies 9
Iulian Vaideanu
Level 4
Level 4
I believe you need the UNIVERSALK9 image for crypto...
Downloaded the new ios for the K9 and checked the boot but the ASR is not picking it up
Router#sh run | sec boot
boot-start-marker
boot system flash asr1001x-universalk9.03.16.02.S.155-3.S2-ext.SPA.bin
boot-end-marker
license boot level adventerprise
IS there a command for same? kindly advise
boot system flash bootflash:/asr1001x-universalk9.03.16.02.S.155-3.S2-ext.SPA.bin
lulian thats not working mate - the crypto features are not coming up
When you said that the ASR "is not picking up" the new image I assumed it was a boot issue...  just to clarify, what IOS image is the device currently running and what exactly is not comming up / cannot be configured?
its not picking up the K9 image i believe
- it should n0t be a boot issue ..see below;
boot-start-marker
The crypto features are not coming up.. check below
Router#dir
Directory of bootflash:/
   11  drwx            16384   Oct 3 2015 05:05:37 +00:00  lost+found
507905  drwx             4096   Jun 8 2016 22:37:07 +00:00  .prst_sync
   12  -rw-        482060536   Oct 3 2015 05:08:14 +00:00  asr1001x-universal.03.13.02.S.154-3.S2-ext.SPA.bin
131073  drwx             4096   Oct 3 2015 05:09:22 +00:00  .installer
622593  drwx             4096  Jan 22 2016 04:44:50 +00:00  core
704513  drwx             4096   Oct 3 2015 05:36:26 +00:00  .rollback_timer
49153  -rw-                0   Oct 3 2015 05:36:34 +00:00  tracelogs.810
475137  drwx            20480   Jun 8 2016 22:42:06 +00:00  tracelogs
49154  -rw-        520582464   Jun 8 2016 21:26:43 +00:00  asr1001x-universalk9.03.16.02.S.155-3.S2-ext.SPA.bin
409601  drwx             4096  Jan 22 2016 04:44:19 +00:00  virtual-instance
81922  -rw-               30   Jun 8 2016 22:37:11 +00:00  throughput_monitor_params
81923  -rw-             1138  Apr 28 2016 22:00:13 +00:00  JAE1938056U_201604282206149000.lic
81924  -rw-             1144  Apr 28 2016 22:00:49 +00:00  JAE1938056U_201604282212059060.lic
for some reason - its has started working working now
mchance
bootflash:asr1002x-universalk9.03.16.01a.S.155-3.S1a-ext.SPA.bin
That is the version you need, specifically the "universalk9" as lulian stated.
did that no luck
