ASR 1001-X - License Explanation
Hi guys,
I have this output from sh license all command on my ASR 1001-X:
Smart Licensing Status
Smart Licensing is ENABLED
License Conversion:
Automatic Conversion Enabled: False
Active: PID:ASR1001-X,SN:xxxxxx
Status: Not started
Standby: PID:ASR1001-X,SN:xxxxx
Status: Not started
Export Authorization Key:
Features Authorized:
<none>
Utility:
Status: DISABLED
Smart Licensing Using Policy:
Status: ENABLED
Data Privacy:
Sending Hostname: yes
Callhome hostname privacy: DISABLED
Smart Licensing hostname privacy: DISABLED
Version privacy: DISABLED
Transport:
Type: cslu
Cslu address: <empty>
Proxy:
Not Configured
Miscellaneous:
Custom Id: <empty>
Policy:
Policy in use: Merged from multiple sources.
Reporting ACK required: yes (CISCO default)
Unenforced/Non-Export Perpetual Attributes:
First report requirement (days): 365 (CISCO default)
Reporting frequency (days): 0 (CISCO default)
Report on change (days): 90 (CISCO default)
Unenforced/Non-Export Subscription Attributes:
First report requirement (days): 90 (CISCO default)
Reporting frequency (days): 90 (CISCO default)
Enforced (Perpetual/Subscription) License Attributes:
First report requirement (days): 0 (CISCO default)
Report on change (days): 0 (CISCO default)
Export (Perpetual/Subscription) License Attributes:
Usage Reporting:
Last ACK received: <none>
Next ACK deadline: Jan 21 17:10:28 2023 UTC
Reporting push interval: 30 days
Next ACK push check: <none>
Next report push: Jan 21 17:12:28 2022 UTC
Last report push: <none>
Last report file write: <none>
Trust Code Installed: <none>
License Usage
adventerprise (ASR_1000_AdvEnterprise):
Description: adventerprise
Count: 1
Version: 1.0
Status: IN USE
Export status: NOT RESTRICTED
Feature Name: adventerprise
Feature Description: adventerprise
Enforcement type: NOT ENFORCED
License type: Perpetual
interface_10g (ASR_1001X_10GE):
Description: interface_10g
Count: 2
Version: 1.0
Status: IN USE
Feature Name: interface_10g
Feature Description: interface_10g
sw_redundancy (ASR_1000_SW_REDUNDANCY):
Description: sw_redundancy
Count: 1
Version: 1.0
Status: IN USE
Feature Name: sw_redundancy
Feature Description: sw_redundancy
Product Information
UDI: PID:ASR1001-X,SN:JAE253700HD
HA UDI List:
Active:PID:ASR1001-X,SN:JAE253700HD
Standby:PID:ASR1001-X,SN:xxxxxxx
Agent Version
Smart Agent for Licensing: 5.0.9_rel/68
License Authorizations
Overall status:
Active: PID:ASR1001-X,SN:xxxxxxxxx
Status: NOT INSTALLED
Status:PAK
Standby: PID:ASR1001-X,SN:xxxxxx
Status:PAK
Legacy License Info:
regid.2015-06.com.cisco.ASR_1000_AdvEnterprise,1.0_855386bf-6b9a-4aae-bc41-6d398da6b2be:
DisplayName: adventerprise
Total available count: 1
Term information:
License type: PERPETUAL
Term Count: 1
regid.2015-08.com.cisco.ASR_1001X_Throughput_2.5G-10G,1.0_b2320dc8-f8f0-48b6-9022-cee0042f0395:
DisplayName: throughput_10g
Description: throughput_10g
Term information:
Term Count: 1
regid.2015-06.com.cisco.ASR_1001X_10GE,1.0_4326e87c-fff3-499d-bcb1-eeb09ec38d38:
DisplayName: interface_10g
Total available count: 2
Term information:
Term Count: 2
I need to know if the 10g throughput license is active or not, I didn't understand what means "Legacy License Info"...
Can you help me?
Thanks in advance
8 Replies 8
balaji.bandi
as per the informaiton you have it :
Count: 2
Version: 1.0
Status: IN USE
BB
Yes but if I check the throughput, it displays 2.5Gb and not 10Gb:
RT01#show platform hardware throughput level
The current throughput level is 2500000 kb/s
What is needed to have 10Gb of throughput?
Try below : configuration to 10GB
config t
(config)#platform hardware throughput level 10000000
save and reload the device i guess.
then once Router come back : issue the command and check :
# show license feature | include Feature|throughput
BB
Leo Laohoo
These three lines are the most important ones.
hi leo,
if i upgrade my ASR1K from 16.9.x (non smart license) to 16.12.x (smart license enabled), will all the "permanent" license be retained and converted to "perpetual"?
is there a need to register the ASR1K to CSSM?
will the ASR1K feature/function retain even if it's not registered to CSSM?
@johnlloyd_13
I am unable to answer the questions because I made sure all our routers are on 16.9.X.
technically they should retain - but not tested. if they looking to move to smart License you need to convert them
if you are cautious I will take TAC suggestion.
BB
johnlloyd_13
Level 9
Level 9
hi,
what IOS-XE did you upgrade your ASR 1001-X?
did you "register" the device to CSSM?
