ASR 1001HX and 1002HX port license?
justinringline
Hi Sir,
I need eight 1G port and enght 10G port in the ASR 1001HX (or in the 1002HX).
How many port license should I buy?
Thanks.
Justin
6 Replies 6
VictorOakTree
The Cisco ASR 1001-HX Router has eight 1GE SFP ports in Bay 0 and eight 1GE SFP or 10GE SFP+ ports in Bay 1 . By default, four ports in Bay 0 and four ports in Bay 1 can be enabled without a license (ports 0 through 3). The remaining ports can be enabled in pairs (ports 4 and 5; and ports 6 and 7) through licenses.
https://www.cisco.com/c/en/us/td/docs/routers/asr1000/install/guide/1001HX_1002HX/b_ASR1001HX-1002HX_HIG/b_ASR1001HX-1002HX_HIG_chapter_0110.html#d26032e287a1635
In that case do you have to purchase 1x  FLSA1-HX-2X10GE or 2x  FLSA1-HX-2X10GE in order to activate the remaining x4 10GE PORTS?
Thank you.
1GE SFP ports 0-3 can be enabled by default.
1GE ports 6 and 7 require a port license. Enabling either port will use one port license.
Licensed ports use a 1GE port license when you install SFP in either 6 or 7 port; or in both 6 and 7 ports.
10GE SFP+ ports 0-3 can be enabled by default.
10GE ports 4 and 5 require a port license. Enabling either port will use one port license.
Licensed ports use a 1GE port license when you install SFP in either 4 or 5 port; or in both 4 and 5 ports.
Licensed ports use a 10GE port license when you install a combination of SFP and SFP+ or SFP+ in both 4 and 5 ports.
10GE ports 6 and 7 require a port license. Enabling either port will use one port license.
Licensed ports use a 10GE port license when you install a combination of SFP and SFP+ or SFP+ in both 6 and 7 ports.
royceg
I am looking for the document for the cisco 1002-HX router series, that shows
all of the commands needed to install additional port licenses.
I was told that the "license install" command would be used.
I've looked through the 1002-hx router hardware installation guide, and the ASR 1000 Series
IOS XE Fuji 16.8.x software configuration guide. I did searches on "license install" and also "license"
and I cannot find these commands listed ANYWHERE in either guide.
Can someone post a link to the document that describes how to install additional port licenses
in the 1002-HX series ASR router?  Thanks.
Guys,
If i needed total of 14 1g SFP ports in ASR1002HX. Do i need to license 10g ports too? because 1g licenses max is TY 2 for 2 ports. Basically, 4 licenses ports. Do i need to enable 10g license port if i needed more 1G ports?
jleveland
Note: Built-in 10-GB ports cannot be reduced to 1-GB speed.
https://www.cisco.com/c/en/us/products/collateral/routers/asr-1000-series-aggregation-services-routers/datasheet-c78-731632.html
FYI: the documentation on the ASRs is lackluster.
