C4221 FACTORY RESET
wanumet
Hi, I have a new cisco 4221 router .
I put in passwords during initial configs and an IP
Unfortunately, now it cannot accept passwords and i cant access it using GUI yet i can successfully ping it.
I have tried several recovery methods using SSH, Serial port and telnet but still not successful
Kindly assist
Initializing Hardware ...
Checking for PCIe device presence...done
System integrity status: 0x610
Rom image verified correctly
System Bootstrap, Version 16.7(5r), RELEASE SOFTWARE
Copyright (c) 1994-2019 by cisco Systems, Inc.
Current image running: Boot ROM0
Last reset cause: PowerOn
ISR4221/K9 platform with 4194304 Kbytes of main memory
no valid BOOT image found
Final autoboot attempt from default boot device...
Located pnp-tech-time
Unsupported package header version (0)
Located pnp-tech-discovery-summary
Unsupported package header version (542470260)
Located isr4200-universalk9_ias.16.08.01.SPA.bin
Package header rev 3 structure detected
IsoSize = 475000832
Calculating SHA-1 hash...Validate package: SHA-1 hash:
calculated CA9EC392:E85DDD2D:A51AD7F8:ED55FF91:525F8890
expected CA9EC392:E85DDD2D:A51AD7F8:ED55FF91:525F8890
RSA Signed RELEASE Image Signature Verification Successful.
Image validated
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software [Fuji], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9_IAS-M), Version 16.8.1, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Tue 27-Mar-18 13:43 by mcpre
PLEASE READ THE FOLLOWING TERMS CAREFULLY. INSTALLING THE LICENSE OR
LICENSE KEY PROVIDED FOR ANY CISCO SOFTWARE PRODUCT, PRODUCT FEATURE,
AND/OR SUBSEQUENTLY PROVIDED SOFTWARE FEATURES (COLLECTIVELY, THE
"SOFTWARE"), AND/OR USING SUCH SOFTWARE CONSTITUTES YOUR FULL
ACCEPTANCE OF THE FOLLOWING TERMS. YOU MUST NOT PROCEED FURTHER IF YOU
ARE NOT WILLING TO BE BOUND BY ALL THE TERMS SET FORTH HEREIN.
Your use of the Software is subject to the Cisco End User License Agreement
(EULA) and any relevant supplemental terms (SEULA) found at
http://www.cisco.com/c/en/us/about/legal/cloud-and-software/software-terms.html.
You hereby acknowledge and agree that certain Software and/or features are
licensed for a particular term, that the license to such Software and/or
features is valid only for the applicable term and that such Software and/or
features may be shut down or otherwise terminated by Cisco after expiration
of the applicable license term (e.g., 90-day trial period). Cisco reserves
the right to terminate any such Software feature electronically or by any
other means available. While Cisco may provide alerts, it is your sole
responsibility to monitor your usage of any such term Software feature to
ensure that your systems and networks are prepared for a shutdown of the
Software feature.
cisco ISR4221/K9 (1RU) processor with 1788426K/6147K bytes of memory.
Processor board ID FGL2518LU5C
2 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
7081983K bytes of flash memory at bootflash:.
0K bytes of WebUI ODM Files at webui:.
%INIT: waited 0 seconds for NVRAM to be available
%Error opening tftp://255.255.255.255/network-confg (Timed out)
%Error opening tftp://255.255.255.255/cisconet.cfg (Timed out)
%Error opening tftp://255.255.255.255/admin-confg (Timed out)
%Error opening tftp://255.255.255.255/admin.cfg (Timed out)
Press RETURN to get started!
admin>
admin>
admin>
admin>
admin>
admin>
admin>
admin>
admin>
admin>
admin>
admin>
admin>
admin>
admin>
admin>
admin>
admin>
admin>
admin>
admin>
admin>
admin>
admin>
admin>
admin>
CRYPTO_PKI: setting trustpoint policy for TP-self-signed-4009722129 to specify TP-self-signed-4009722129 keypair usageFailed to generate persistent self-signed certificate.
Secure server will use temporary self-signed certificate.
admin>en
Password:
Password:
Password:
% Bad secrets
admin>
admin>
Leo Laohoo
