ASR 1002 boot broblem
hi,
after ı power off and power on my asr 1002 there is n error in console screen ,
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash contained errors which were auto-corrected.
asr doesnt work and it emergeny !! please help
Richard Burts
Perhaps you could post the entire set of messages generated during the boot process? This might give us better insight into the problem and perhaps then we might have better suggestions.
Do you have more than one image for the ASR1002 in bootflash? If so can you try to manually boot the other image?
Rick
Rick
