ASR 1002-F Compatibility Question
So I have a Cisco ASR 1002-F and with no module I think it can only do 1 gig links. While looking at the modules I can see SPA-4XOC12-POS has 4 interfaces that can do 10 gig SFP's, but the data sheets are not that clear as to if it will support it. Can anyone tell me if this setup would work as I would much like to have 10 gig links vs 1 gig links.
https://www.cisco.com/c/en/us/td/docs/routers/asr1000/install/guide/asr1routers/asr-1000-series-hig/asr-hig-1002f.html
https://www.cisco.com/c/en/us/products/collateral/routers/12000-series-routers/product_data_sheet0900aecd804dfd10.html
Giuseppe Larosa
Hello @ncombs1407621308 ,
the SPA supports 4 ports POS OC12 not 10 GE
if you mean as aggregate your understanding is not correct see link below
https://en.wikipedia.org/wiki/Optical_Carrier_transmission_rates
Each OC-12 is able to carry 622 Mbps so 4 of them roughly counts for 2,4 Gbps
OC-48 is 2,4 Gbps
And of course you need to connect each of them to another POS interface at the same speed
Hope to help
Giuseppe
Giuseppe Larosa
OC-48 is 2,4 Gbps
Hope to help
Giuseppe
Thank you that's what I needed to know.
balaji.bandi
not sure what is the requirement - You looking to install   SPA-4XOC12-POS in ASR 1002-F ?
BB
Its more of a question of if the device can do something rather than a requirement. So the ASR 1002-F has 4 fixed SFP interfaces which I assume are capped at 1 gig each (according to https://www.cisco.com/c/en/us/products/collateral/routers/asr-1000-series-aggregation-services-routers/data_sheet_c78-441072.html), and so I looked at modules that would supposedly work with the ASR 1002-F. In doing so SPA-4XOC12-POS stuck out as 4 interfaces with the capability to use 10 gig SFP's, but as Giuseppe Larosa pointed out OC12 is capped at 622.08 Mbit/s. This meaning the module would be able to support 10 gig SFP's but would xfer less than a gig per interface or that's at least how I understood it. I'm also kind of bad at this so any help is appreciated.
