ASR 1002 Memory log
scottmanzie1
Got an ASR 1002 running asr1000rp1-ipbasek9.02.06.02.122-33.XNF2.bin
Getting this log filling up the router
Apr 30 03:51:26 BST: %PLATFORM-4-ELEMENT_WARNING: R0/0: smand:  ESP/0: Committed Memory value 304% exceeds warning level 300%
*Apr 30 04:01:36 BST: %PLATFORM-4-ELEMENT_WARNING: R0/0: smand:  ESP/0: Committed Memory value 304% exceeds warning level 300%
*Apr 30 04:11:46 BST: %PLATFORM-4-ELEMENT_WARNING: R0/0: smand:  ESP/0: Committed Memory value 304% exceeds warning level 300%
*Apr 30 04:21:56 BST: %PLATFORM-4-ELEMENT_WARNING: R0/0: smand:  ESP/0: Committed Memory value 304% exceeds warning level 300%
*Apr 30 04:32:06 BST: %PLATFORM-4-ELEMENT_WARNING: R0/0: smand:  ESP/0: Committed Memory value 304% exceeds warning level 300%
*Apr 30 04:42:16 BST: %PLATFORM-4-ELEMENT_WARNING: R0/0: smand:  ESP/0: Committed Memory value 304% exceeds warning level 300%
*Apr 30 04:52:26 BST: %PLATFORM-4-ELEMENT_WARNING: R0/0: smand:  ESP/0: Committed Memory value 304% exceeds warning level 300%
Initially I thought this was a memory leak but on the output of ""show plat software stat control-processor brief"" although the ESP shows warning the free memory is not steadily decreasing.  The output below is in order run 6 times over a few days.  As you can see its varying up and down which seems normal
Memory (kB)
 Slot  Status    Total     Used (Pct)     Free (Pct) Committed (Pct)
  RP0 Healthy  3706232  1511096 (41%)  2195136 (59%)   2490812 (67%)
 ESP0 Warning   980592   974160 (99%)     6432 (1%)   2974868 (303%)
 SIP0 Healthy   477712   351752 (74%)   125960 (26%)    257132 (54%)
Memory (kB)
  RP0 Healthy  3706232  1511460 (41%)  2194772 (59%)   2490828 (67%)
 ESP0 Warning   980592   971040 (99%)     9552 (1%)   2978588 (304%)
 SIP0 Healthy   477712   351752 (74%)   125960 (26%)    257260 (54%)
Memory (kB)
  RP0 Healthy  3706232  1511460 (41%)  2194772 (59%)   2490832 (67%)
 ESP0 Warning   980592   972392 (99%)     8200 (1%)   2980028 (304%)
 SIP0 Healthy   477712   351876 (74%)   125836 (26%)    257260 (54%)
Memory (kB)
  RP0 Healthy  3706232  1511460 (41%)  2194772 (59%)   2490852 (67%)
 ESP0 Warning   980592   974292 (99%)     6300 (1%)   2981780 (304%)
Memory (kB)
  RP0 Healthy  3706232  1511584 (41%)  2194648 (59%)   2490856 (67%)
 ESP0 Warning   980592   974268 (99%)     6324 (1%)   2982452 (304%)
 SIP0 Healthy   477712   351876 (74%)   125836 (26%)    257388 (54%)
Memory (kB)
 ESP0 Warning   980592   974208 (99%)     6384 (1%)   2982500 (304%)
I am now thinking this could be a cosmetic bug I've found some similar
Any thoughts?
Did anyone find out anything on this one?
seeing similar memory issues with and esp5 running two BGP4 full tables
RP0 Healthy 3874492 3113704 (80%) 760788 (20%) 2938904 (76%)
ESP0 Warning 969076 956136 (99%) 12940 ( 1%) 886928 (92%)
SIP0 Healthy 471820 306768 (65%) 165052 (35%) 248432 (53%)
Mark Elsen
 - Could be a bug :
         https://bst.cloudapps.cisco.com/bugsearch/bug/CSCva63723/?rfs=iqvred
 M.
