ASR 1002 X Donnot Redistributed recieved BGp routes
Hi router A announce prefix x.x.x.x/y to routerB on IBGP
router B IS asr1002X by donnot redistruited prefix    x.x.x.x/y To uplink internet bgp session
Router is exsited in routing table router A by IBGp distance 200
uplink internet advertise routes limit by prefix-list and in prefix-list x.x.x.x/y exsited
How solve this  ????
any idea?
Hello admin@atrinnet.net ,
iBGP means that the peer is in the same AS as the device that originated the prefix.
Two options here or you make Router B the route reflector server or you create a direct iBGP session between RA and RC
Hope to help
Giuseppe
25 Replies 25
MHM
For ebgp under router a uplink is router A
whitch command need B that redistribued Router B prefix on internet uplink ???
MHM
Giuseppe Larosa
check all the BGP attributes attached to the prefix x.x.x.x/y using
show ip bgp x.x.x.x/y
on RouterB
look at the BGP communities values attached to it if you see the well known BGP community no-export or NO-EXPORT this a possible reason why RouterB does not advertise the prefix to ISP.
no-export BGP community allows a prefix to be propagated within an AS in iBGP but it does not allow to advertise it to an eBGP peer.
the BGP next-hop cannot be an issue by default BGP next-hop is rewritten over an eBGP session using the IP address used to talk with  the eBGP peer.
Hope to help
Giuseppe
the community is none
BGP routing table entry for x.x.x.x/y, version 22811
Paths: (1 available, best #1, table default)
Not advertised to any peer
Refresh Epoch 1
208555 51026, (received & used)
172.18.22.22 from 172.18.22.22 (185.217.6.50)
Origin IGP, localpref 100, valid, internal, best
rx pathid: 0, tx pathid: 0x0
Updated on Aug 19 2024 14:58:34 UTC
show in bgp no advetise to any peers
now
show ip bgp neighbors 172.18.14.253 advertised-routes
Total number of prefixes 0
172.18.14.253 is uplink router B
Hi admin@atrinnet.net ,
The "Not advertised to any peer" leads me to believe that the prefix list does not really allow this specific prefix. Can you do a "show bgp ipv4 unicast <prefix-list name>" on router B and see if the command returns the specific prefix.
Hi Dears
Bgp neighbor limitation
address-family ipv4
bgp redistribute-internal
neighbor 172.18.14.253 activate
neighbor 172.18.14.253 route-map edge out
route-map section :
show route-map edge
route-map edge, permit, sequence 1
Match clauses:
ip address prefix-lists: mobin
Set clauses:
Policy routing matches: 0 packets, 0 bytes
prefix include
show ip prefix-list mobin
ip prefix-list mobin: 2 entries
seq 5 permit 45.129.36.0/24 le 32
seq 1000 deny 0.0.0.0/0 le 32
show ip bgp 45.129.36.0/24
BGP routing table entry for 45.129.36.0/24, version 22811
Refresh Epoch 1
rewrite the prefix-list in the following manner:
no seq 5 permit 45.129.36.0/24 le 32
without adding the le 32 the prefix-list will look for an exact match with your prefix. The current statement looks for prefixes that are within 45.129.36.0/24 but the prefix itself is not a match.
Hope to help
Giuseppe
Hi Giuseppe,
This prefix list entry should be fine and will definitely permit 45.129.36.0/24.
Hello @Harold Ritter ,
yes we have been confused by the fact the OP admin@atrinnet.net made us to think of an eBGP session , but it is now clear it is an iBGP session and this explains why RB cannot advertise the prefix to RC for the iBGP split horizon rule.
either he makes a direct iBGP session between RA and RC or it has to configure RB as a route reflector server by adding neighbor x.x.x.x route-reflector-client under BGP or under the correct address family.
Hope to help
Giuseppe
Try performing a "clear bgp ipv4 unicast * soft". You should perform this command every time you change your BGP policies.
ok BGP communities are not an issue here
at this point I agree with @Harold Ritter verify if the prefix-list allows the prefix or not.
Hope to help
Giuseppe
Hello
Can you confirm if the "internet" bgp peering is in the same ASN as rtr A/B ?, if so then the route will not be advertised, due to ibgp split horizon initiating --- a received ibgp route will not be readvertised to another ibgp peer
Kind Regards
Paul
when used show ip protocols donnot show me any route-maps assign to bgp neigbors
show ip protocols
*** IP Routing is NSF aware ***
Routing Protocol is "application"
Sending updates every 0 seconds
Invalid after 0 seconds, hold down 0, flushed after 0
Outgoing update filter list for all interfaces is not set
Incoming update filter list for all interfaces is not set
Maximum path: 32
Routing for Networks:
Routing Information Sources:
Gateway Distance Last Update
Distance: (default is 4)
Routing Protocol is "bgp 204203"
IGP synchronization is disabled
Automatic route summarization is disabled
Neighbor(s):
Address FiltIn FiltOut DistIn DistOut Weight RouteMap
172.18.14.253
172.18.19.13
