ASR 1002-X ESP
Joshuskarki
I am in a new environment where I see few ASR 1002-x series routers.
I wonder how I can make sure these are on which ESP license level.
Is there any command I can run and verify?
Josh
License State: Active, Not in Use, EULA not accepted
It means the Evaluation license has been invoked/enabled but not in use because the EULA hasn't been accepted.
6 Replies 6
Leo Laohoo
sh license
This is where I get confused.
If you look at the index from 26 to 31, all level of throughputs are being activated and period left: 8  weeks 4  days. So what will happen after this, it just runs on default throughput which is 5G I believe? I don't have quote/PO to go back and look what was on the order.
Thanks for your help!
#sh license
Index 1 Feature: adventerprise
        Period left: Life time
        License Type: Permanent
        License State: Active, In Use
        License Count: Non-Counted
        License Priority: Medium
Index 2 Feature: advipservices
        Period left: 8  weeks 4  days
        License Type: EvalRightToUse
        License Priority: None
Index 3 Feature: ipbase
Index 4 Feature: avc
Index 5 Feature: broadband
Index 6 Feature: broadband_4k
Index 7 Feature: cube_250
Index 8 Feature: cube_250_red
Index 9 Feature: cube_ent_100
Index 10 Feature: cube_ent_100_red
Index 11 Feature: cube_lab
Index 12 Feature: cube_video_b2btp
Index 13 Feature: cube_video_b2btp_red
Index 14 Feature: firewall
Index 15 Feature: fpi
Index 16 Feature: fwnat_red
Index 17 Feature: gtp_addon_aic
Index 18 Feature: internal_service
Index 19 Feature: ipsec
Index 20 Feature: lawful_intr
Index 21 Feature: lisp
Index 22 Feature: nat64_stateful_2m
Index 23 Feature: otv
Index 24 Feature: sgt_fw
Index 25 Feature: sw_redundancy
Index 26 Feature: throughput_10g
Index 27 Feature: throughput_10g_to_20g
Index 28 Feature: throughput_10g_to_36g
Index 29 Feature: throughput_20g
Index 30 Feature: throughput_20g_to_36g
Index 31 Feature: throughput_36g
Index 32 Feature: vpls
Aah! I see.. Thanks a lot Leo!
-Josh
Thanks for taking the time to rate our posts.  :)
In addition to "sh license" command if you want to know what license the device is running, you can issue "sh ver" you should see something like this:
License Level: adventerprise
Next reload license Level: adventerprise
This is if you have advanced enterprise license installed.
