02-16-2017 12:11 AM - edited 03-05-2019 08:02 AM
Hello Experts
we discuss about BGP return traffic issue is comes
actually i have 3 ISP links it is connceted on single router
i have adverties only one ip public pool ex. 103.205.x.x/24
ISP 1 =20 mb ----active
ISP 2 =4 mb ---- passive
ISP 3 =4 mb ---- passive
in this situation my IN traffic it will come 20 mb
but my retun direction traffic it has been come to 4 mb ISP 2
i want to my return traffic will be come to 20mbps
i try to put AS-Path prepend on but still traffic has come to 4 mbps
what to do please help me
Thanks in avd
02-16-2017 12:33 AM
have you tried local preference on your router ? Post the config, you might be missing something...
02-16-2017 01:25 AM
Yes, i have put local pref
ISP 1 = 300
ISP 2= 200
ISP 3=150
create two prefix-list
ip prefix-list DEFAULT_ROUTE: 1 entries
seq 5 permit 0.0.0.0/0
ip prefix-list PREFIX_OUT: 1 entries
seq 5 permit 103.205.x.x/24
also Route map
route-map ALL_PREFIX_OUT permit 10
match ip address prefix-list PREFIX_OUT
route-map ISP1_IN permit 10
match ip address prefix-list DEFAULT_ROUTE
set local-preference 300
route-map ISP2_IN permit 10
set local-preference 200
route-map ISP3_IN permit 10
set local-preference 150
it is correct my prefix-list and route-map
02-16-2017 04:08 AM
try and connfigure the default preference as below:
R1
bgp default local-preference 200
R2
bgp default local-preference 150
R3
bgp default local-preference 100
02-17-2017 02:52 AM
Hello
actually i have 3 ISP links it is connected on single router
In this scenario I wouldn't use LP
As this is only one router connecting to 3 EBGP isp peers, use the weight attribute for outgoing traffic section.
This weight attribute is locally significant and has an higher path selection than the Local preference.
router bgp xx
neighbor ISP1 weight 50000
neighbor ISP2 weight 40000
neighbor ISP3 weight 30000
res
Paul
