ASR 1002-X port MGMT
Hello
Can tell me if port of ASR1002-X with label MGMT is possible configure for LAN traffic in production?
Thanks.
5 Replies 5
Leo Laohoo
MGMT ports are only for Out of Band Management (OoBM) use only.
MGMT port is not connected to ESP. So it cannot be used as usual port.
Hi Evgeniy, I am confused, last reply interpreter was not possible for LAN traffic, my problem is I do not buy to this team SFP thinking that the base already included default, which is why we seek if the MGMT can be a normal network port for use without buying sFP for that.
can you detail this?
my fault, sorry. i've changed my message a bit. So you must buy sfp..
Ok I understand, Thanks you.
