12-18-2009 12:46 AM - edited 03-04-2019 07:01 AM
Dear team,
We have an Cisco ASR 1004 router. there is a traffic marking performed in LAN L3 switch. The Marked traffic is then forwarded to ASR 1004.
To our surprise, we have observed that the ASR 1004 is forwarding packets out VIA the WAN interfaces without any Marking.
We have confirmed with Special software that traffic entering the LAN interface of ASR 1004 is having proper Marking (DSCP marking on the header)...
But for the same traffic is the WAN out is analyzed, we could find that all traffic is traversing without any marking... It seems that ASR is removing all Marking from IP header.
Please help with your view in this problem
with regards,
Prasad. K
12-18-2009 07:46 AM
Hi Prasad,
Are you using any encapsulation before sending the trafic to the WAN (IPSec,..)
Laurent.
03-23-2010 10:49 AM
Hi Prasad - I've been researching this a little.
What is the interface to the ASR - is it a trunk or L2/L3 port?
I have a trunk port with ethernet sub-interfaces. On the sub-interface I care about - I have a service-policy input on the interface that marks traffic w/ IP Prec according to how our provider requires them to place in the proper queue's across the MPLS backbone. The applications I care about do not mark - and even if they did - I wouldn't trust them. Anyway it looks something like this (very simple):
class-map match-any real-time
match access-group name real-time
class-map match-any enterprise-apps
match access-group name enterprise-apps
policy-map setTOS
class real-time
set ip precedence 4
class enterprise-apps
set ip precedence 1
class class-default
set ip precedence 0
interface GigabitEthernet0/0/0.560
encapsulation dot1Q 560
ip vrf forwarding global
ip address
service-policy input setTOS
This works well. But I also know that the ASR should honor marking as they come in. That's where I think this doc / CCO link comes in
I wonder if you need to add the:
aspeg-casr-01(config-subif)#plim qos input map cos enable
Then:
aspeg-casr-01(config-subif)#plim qos input map cos 5 queue strict-priority
Per your requirements. That schedules packets with cos 5 ahead of the line for processing in the ESP...read the link above for theory of packet processing w/ QoS on the ASR. You'd still need to apply an outbound service policy via MQC if you want to prioritize outbound traffic.
