ASR 1006 Redundancy Mode
MP13
I've just taken over administering some ASR 1006's and after adding them to our monitoring it's flagging up that the redundancy is currently configured mode SSO but operational mode is non redundant.
We run two of them independently with BGP and VRRP configured for the resiliency that we need and do not use the inbox or box to box redundancy features.
I saw some examples where the redundancy is set to "mode none" but I don't have that option. I only have rpr or sso.
Is there something else I should do to set redundancy to none or should it just be left as it is?
pieterh
look at this post and the link to requirement the router needs
Solved: ASR1001 - Redundancy mode issues (operational vs configured) - Cisco Community
skarthic :
Have you made sure the basic requirements for ASR1001 HA is present? Please check the link here
http://www.cisco.com/en/US/docs/routers/asr1000/configuration/guide/chassis/issu.html#wp1218296
We would be needing a 8 GB DRAM and a license for configuring software redundancy.
Thank you for the reply.
I have reviewed those links previously but unfortunately they don't answer my query. I'm not looking to use in-box or box-to-box HA so there are no minimum requirements that need to be met. I'm looking to make sure my redundancy mode is set to the correct mode, i.e. "none" so that the error is cleared.
what is the hardware configuration, does it have a dual RP ?
It is single RP. We achieve our resilience in BGP and VRRP we do not use any ASR HA features.
