ASR-1006
botelho.rocha1
.Jan 6 12:22:40 GMT+1: %CPPHA-7-START: F0: cpp_ha: CPP 0 preparing image /tmp/sw/fp/0/0/fp/mount/usr/cpp/bin/qfp-ucode-esp10
.Jan 6 12:22:41 GMT+1: %CPPHA-7-START: F0: cpp_ha: CPP 0 startup init image /tmp/sw/fp/0/0/fp/mount/usr/cpp/bin/qfp-ucode-esp10
Password:
.Jan 6 12:22:46 GMT+1: %CPPOSLIB-3-ERROR_NOTIFY: F0: cpp_driver-0: cpp_driver-0 encountered an error -Traceback= 1#d1babdf44dc893e5cee82b5a267753da errmsg:F39B000+2250 cpp_common_os:FA07000+BBC0 cpp_common_os:FA07000+B9D0 cpp_drv_cmn:FB52000+1A22B0 cpp_drv_cmn:FB52000+C3E70 cpp_drv_cmn:FB52000+DC0C8 cpp_drv_cmn:FB52000+DF8C8 cpp_drv_cmn:FB52000+BEC10 cpp_drv_cmn:FB52000+BEF30 :10000000+7124 :10000000+7CFC cpp_drv_cmn:FB52000+19B11C binos:F641000+BC1C cpp_drv_cmn:FB52000+19B228 :10000000+7534 :10000000+EB5C cp
.Jan 6 12:22:46 GMT+1: %CPPDRV-3-FATAL_MEM_CLEAR: F0: cpp_driver-0: CPP0: (0x6e) Failed to clear memory 'cpp/driver' detected the 'warning' condition 'CPP driver error in devobj layer': Connection timed out -Traceback= 1#d1babdf44dc893e5cee82b5a267753da errmsg:F39B000+2250 cpp_drv_cmn:FB52000+19E9A0 cpp_drv_cmn:FB52000+BEC7C cpp_drv_cmn:FB52000+BEF30 :10000000+7124 :10000000+7CFC cpp_drv_cmn:FB52000+19B11C binos:F641000+BC1C cpp_drv_cmn:FB52000+19B228 :10000000+7534 :10000000+EB5C cpp_client_ha:FAEB000+2F08
.Jan 6 12:22:46 GMT+1: %CPPHA-3-FAULT: F0: cpp_ha: CPP:0.0 desc:DPE7_CPE_CPE_DPE_INT_SET_0_LEAF_INT_INT_PHY_ERROR det:DRVR(interrupt) class:OTHER sev:FATAL id:1723 cppstate:STOPPED res:UNKNOWN flags:0x3 cdmflags:0x5
.Jan 6 12:22:46 GMT+1: %CPPHA-3-FAULTCRASH: F0: cpp_ha: CPP 0.0 unresolved fault detected, initiating crash dump.
.Jan 6 12:22:46 GMT+1: %CPPHA-3-FAULT: F0: cpp_ha: CPP:0.0 desc:DPE7_CPE_CPE_DPE_DUI_LEAF_INT_INT_DUI_CHN0_DRAM_MBE det:DRVR(interrupt) class:MBE sev:FATAL id:1752 cppstate:STOPPED res:SUCCESS flags:0x3 cdmflags:0x5
.Jan 6 12:22:46 GMT+1: %CPPDRV-3-FATAL_INIT_ID: F0: cpp_driver-0: CPP0: (0x1) Failed to initialize init device drivers(s) - Operation not permitted -Traceback= 1#d1babdf44dc893e5cee82b5a267753da errmsg:F39B000+2250 cpp_drv_cmn:FB52000+19EC48 :10000000+7148 :10000000+7CFC cpp_drv_cmn:FB52000+19B11C binos:F641000+BC1C cpp_drv_c
re-ld-tcc-02_ASR1006#mn:FB52000+19B228 :10000000+7534 :10000000+EB5C cpp_client_ha:FAEB000+2F08 cpp_common_os:FA07000+10AA4 cpp_common_os:FA07000+110DC evlib:F6FC000+E0EC evlib:F6FC000+104D4 :10000000+6B20 c
.Jan 6 12:22:46 GMT+1: %CPPHA-3-INITFAIL: F0: cpp_ha: CPP 0 initialization failed - startup init (0x1)
.Jan 6 12:22:46 GMT+1: %CPPHA-3-INITFAIL: F0: cpp_ha: CPP 0 initialization failed - start CPP (0x1)
.Jan 6 12:22:46 GMT+1: %IOSXE-3-PLATFORM: F0: cpp_cdm: CPP crashed, core file /tmp/corelink/re-ld-tcc-02_ASR1006_
re-ld-tcc-02_ASR1006#ESP_0_cpp-mcplo-ucode_010621112246.core.gz
balaji.bandi
is this Only  logs one time generated or module keep rebooting.
Try to turn off module and ON the module and errors disappear good, if not this could a bug or required replacement.
BB
5 Replies 5
balaji.bandi
BB
Good morning people,
Thank you all for your help and I would like to inform you that I really have to update the equipment's firmware because it is a very old version of the ASR-1006
there should be a crash file or coredump somewhere on the router. Try to find that using:
show bootflash: | inc crash
show stby-bootflash: | inc crash
show stby-harddisk: | inc core
show harddisk: | inc core
Have a look at the links below to help you start troubleshooting:
How To Troubleshoot Crashes on an ASR-1006 Router
https://www.routerfreak.com/troubleshoot-crashes-asr1006/
Troubleshoot Cisco ASR 1000 Series Aggregation Services Routers Crashes
https://www.cisco.com/c/en/us/support/docs/routers/asr-1000-series-aggregation-services-routers/109723-asr-crash.html
Mark Elsen
 - Could be a bug too , as already stated - e.g : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCue48328
    You may first consider upgrading the ASR to the latest advisory and or gold-starred release , if applicable and feasible. Check if the problem persists afterwards.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Leo Laohoo
What firmware is this router running on?
