ASR 903 BFD dampening
I try to configure BFD dampening on a Cisco ASR903. Does anyone have an idea what license level or software allows me to do that? Up to now I had not success using metroaggservices or metroipservices (17.5.6).
M02@rt37
Hello @MATTHIAS SCHAERER
Which RSP ? 1,2 or 3 ?
RSP 2 with vers IOS version 17.3.1 is Ok
https://www.cisco.com/c/dam/en/us/td/docs/wireless/asr_900/compatibility/matrix/Compatibility-Matrix-ASR900.pdf
Best regards
M02@rt37
Best regards
Hi M02@rt37
Thanks a lot for the matrix. It's RSP3 that I have, so bad news for me. You don't know by accident, if there are any plans to integrate the feature on RSP3?
Anyway, thanks for the fast reply. That already clarifies why I have not found the possibility to configure it.
cheers mat
You're so welcome @MATTHIAS SCHAERER
unfortunately not...
Best regards
No worries, having an answer (even if it's a negative one) helps to proceed.
Have a nice day and thanks again.
