ASR 903 ISSU upgrade
jigojar
    I could not able to do the ISSU, Can you please help.
ROUTER#request platform software package install rp 1 file stby-bootflash:/Image/asr900rsp3-universalk9.03.18.03.SP.156-2.SP3-ext.bin
Fri Apr 27 14:46:14 IST 2018 --- Starting local lock acquisition on R0 ---
Fri Apr 27 14:46:14 IST 2018 Finished local lock acquisition on R0
Fri Apr 27 14:46:14 IST 2018 --- Starting installation state synchronization ---
Fri Apr 27 14:46:14 IST 2018 Finished installation state synchronization
Fri Apr 27 14:46:17 IST 2018 --- Starting local lock acquisition on R1 ---
Fri Apr 27 14:46:17 IST 2018 Finished local lock acquisition on R1
Fri Apr 27 14:46:17 IST 2018 --- Starting file path checking ---
Fri Apr 27 14:46:17 IST 2018 Finished file path checking
Fri Apr 27 14:46:17 IST 2018 --- Starting image file verification ---
Fri Apr 27 14:46:17 IST 2018 Checking image file names
Fri Apr 27 14:46:17 IST 2018 Locating image files and validating name syntax
Fri Apr 27 14:46:17 IST 2018 Found asr900rsp3-universalk9.03.18.03.SP.156-2.SP3-ext.bin
Fri Apr 27 14:46:17 IST 2018 Verifying image file locations
Fri Apr 27 14:46:17 IST 2018 FAILED: Package files must reside in same location as provisioning file 'bootflash:packages.conf'
ROUTER#dir bootflash:/Image
Directory of bootflash:/Image/
425154 -rw- 496135196 Apr 27 2018 02:40:05 +05:30 asr900rsp3-universalk9.03.18.03.SP.156-2.SP3-ext.bin
490627 -rw- 208643052 Apr 27 2018 02:42:59 +05:30 asr900rsp3-espbase.03.18.03.SP.156-2.SP3-ext.pkg
490628 -rw- 7438 Apr 27 2018 02:43:07 +05:30 asr900rsp3-packages-universalk9.03.18.03.SP.156-2.SP3-ext.conf
490629 -rw- 23315436 Apr 27 2018 02:43:12 +05:30 asr900rsp3-rpaccess.03.18.03.SP.156-2.SP3-ext.pkg
490630 -rw- 36178924 Apr 27 2018 02:43:19 +05:30 asr900rsp3-rpbase.03.18.03.SP.156-2.SP3-ext.pkg
490631 -rw- 32717808 Apr 27 2018 02:43:27 +05:30 asr900rsp3-rpcontrol.03.18.03.SP.156-2.SP3-ext.pkg
490632 -rw- 77397028 Apr 27 2018 02:43:36 +05:30 asr900rsp3-rpios-universalk9.03.18.03.SP.156-2.SP3-ext.pkg
490633 -rw- 18420716 Apr 27 2018 02:43:44 +05:30 asr900rsp3-sipbase.03.18.03.SP.156-2.SP3-ext.pkg
490634 -rw- 104465388 Apr 27 2018 02:43:53 +05:30 asr900rsp3-sipspa.03.18.03.SP.156-2.SP3-ext.pkg
490635 -rw- 8223 Apr 27 2018 02:44:06 +05:30 packages.conf
6185086976 bytes total (3426885632 bytes free)
ROUTER#
ROUTER#dir stby-bootflash:/Image
Directory of stby-bootflash:/Image/
457858 -rw- 394589204 Jan 21 2016 13:17:32 +05:30 asr900rsp3-universalk9_npe.03.17.00.S.156-1.S-std.bin
457860 -rw- 141999080 Jan 21 2016 13:55:44 +05:30 asr900rsp3-espbase.03.17.00.S.156-1.S-std.pkg
457861 -rw- 7298 Jan 21 2016 13:55:51 +05:30 asr900rsp3-packages-universalk9_npe.03.17.00.S.156-1.S-std.conf
457862 -rw- 23266284 Jan 21 2016 13:55:56 +05:30 asr900rsp3-rpaccess.03.17.00.S.156-1.S-std.pkg
457863 -rw- 34497512 Jan 21 2016 13:56:01 +05:30 asr900rsp3-rpbase.03.17.00.S.156-1.S-std.pkg
457864 -rw- 31595500 Jan 21 2016 13:56:08 +05:30 asr900rsp3-rpcontrol.03.17.00.S.156-1.S-std.pkg
457865 -rw- 74966044 Jan 21 2016 13:56:16 +05:30 asr900rsp3-rpios-universalk9_npe.03.17.00.S.156-1.S-std.pkg
457866 -rw- 17626088 Jan 21 2016 13:56:23 +05:30 asr900rsp3-sipbase.03.17.00.S.156-1.S-std.pkg
457867 -rw- 75506664 Jan 21 2016 13:56:30 +05:30 asr900rsp3-sipspa.03.17.00.S.156-1.S-std.pkg
457877 -rw- 8223 Apr 27 2018 05:23:40 +05:30 packages.conf
457859 -rw- 496135196 Apr 27 2018 02:44:46 +05:30 asr900rsp3-universalk9.03.18.03.SP.156-2.SP3-ext.bin
457869 -rw- 208643052 Apr 27 2018 05:22:45 +05:30 asr900rsp3-espbase.03.18.03.SP.156-2.SP3-ext.pkg
457870 -rw- 7438 Apr 27 2018 05:22:53 +05:30 asr900rsp3-packages-universalk9.03.18.03.SP.156-2.SP3-ext.conf
457871 -rw- 23315436 Apr 27 2018 05:22:57 +05:30 asr900rsp3-rpaccess.03.18.03.SP.156-2.SP3-ext.pkg
457872 -rw- 36178924 Apr 27 2018 05:23:03 +05:30 asr900rsp3-rpbase.03.18.03.SP.156-2.SP3-ext.pkg
457873 -rw- 32717808 Apr 27 2018 05:23:09 +05:30 asr900rsp3-rpcontrol.03.18.03.SP.156-2.SP3-ext.pkg
457874 -rw- 77397028 Apr 27 2018 05:23:15 +05:30 asr900rsp3-rpios-universalk9.03.18.03.SP.156-2.SP3-ext.pkg
457875 -rw- 18420716 Apr 27 2018 05:23:22 +05:30 asr900rsp3-sipbase.03.18.03.SP.156-2.SP3-ext.pkg
457876 -rw- 104465388 Apr 27 2018 05:23:29 +05:30 asr900rsp3-sipspa.03.18.03.SP.156-2.SP3-ext.pkg
6185086976 bytes total (568225792 bytes free)
ROUTER#
0 Replies 0
