ASR 903 upgrade: ISSU compatibility check failed
mfahmy
Dears,
I am facing the below error with ASR903 upgrade even i am following the procedure in the below document.
Error message:
--- Starting ISSU compatibility verification ---
FAILED: ISSU compatibility check failed
*Dec  4 11:20:33.950: %INSTALL-3-OPERATION_ERROR_MESSAGE:  SIP1: provision.sh:  Failed to install package stby-bootflash:Image/*rsp3-*16.09.01a.SPA.pkg, Error: ISSU compatibility check failedFAILED: Stage 1 for sub-package node ISSU failed
"https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ha/configuration/xe-3s/asr903/16-6-1/b-ha-xe-16-6-asr900/ha-install-upgrad-software.pdf"
The only difference is that i changed the command of the:
"boot system bootflash:Image/packages.conf"
to
"boot system bootflash:Image/asr900rsp3-universalk9.16.09.01a.SPA.conf"
after i received the below message when i was expanding the package from bootflash:
Router#$file bootflash:/Image/asr900rsp3-universalk9.16.09.01a.SPA.bin
Verifying parameters
Expanding superpackage bootflash:Image/asr900rsp3-universalk9.16.09.01a.SPA.bin
Validating package type
Copying package files
  WARNING: A different version of provisioning file packages.conf already exists in bootflash:Image
  WARNING: The provisioning file from the expanded bundle will be saved as
  WARNING: bootflash:Imageasr900rsp3-universalk9.16.09.01a.SPA.conf
SUCCESS: Finished expanding all-in-one software package.
Router#
Any one know what is the root cause and how can i fix it
mfahmy
I think i found a work around to the upgrade but not for ISSU !!
  1. Fix the boot system sequence:
      • boot system bootflash:Image/packages.conf
      • boot system bootflash:Image/asr900rsp3-universalk9.16.09.01a.SPA.conf
    • To:
  2. Save (wr mem)
  3. Reload the router !!
Router reloaded with the new IOS-XE (upgrade from 16.05.01 to 16.09.01a) ...but this is not In-Service Software Upgrade (ISSU) !
