Dual internet implementation with Router
mrochac
Good day everyone, i need some advice on best practice for the following scenario;
- we have 2 CE routers ISP owned providing MPLS access to our WAN
- we would like to install 2 routers and load balance between them which should also provide redundancy
any help is great appreciated.
in addition to Balaji's post the below is also a good collection of sample configs:
http://showipbgp.com/bgp-configurations/cisco.html
balaji.bandi
Look at good example for reference :
https://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/13762-40.html#anc15
BB
Hello
if you already have ce rtrs then the resiliency is already being provided -  a High end L3 switch (stackwise virtual or vss) running an igp such has ospf or floating static routes  would be applicable
On the basis what you have posted regards your design at present i would say you really don’t need rtrs unless you have a specific requirement for them.
Kind Regards
Paul
