ASR-920 Port Channel Support
ZK916
We currently have a Cisco ASR-920-4SZ edge router which has a single 10G link to a stack of edge switches. We are trying to build a fault-tolerance by configuring a port-channel and configuring 2 X 10G interfaces. I wanted to find out if that ASR-920-4SZ router support port-channeling (L2 or L3 port-channeling). Any thoughts?
Thanks in advance.
Best, ~zK
I already lab this before
IOS XE support PO L3 and you can use mode ON
ZK916
@MHM Cisco World .. thanks for quick reply.
Does it also support PO L2?
I dont try before but
if you try
interface port-channel x
switch port <<- if this accept by ASR then you can config it
