ASR 9901 capabilities
I would like to know the performance capabilities of the ASR 9901 fixed chassis or at least which RSP is based in.
Right now for the ASR 9001 i have the following and i want something similar:
FEATURE:
Total Queues: 256K / NP
Policers: 256K / NP
Ethernet Flow Point (EFPs): 64K
FIB Routes: (v4/v6) 4M/2M
MAC Addresses: 2M
L3 VRFs: 8K
Bridge Domains / VFI: 64K
Thanks!
omz
For me .. Cisco SE best POC for this sort of info.
This may help - https://null.53bits.co.uk/index.php?page=asr9000-series-hardware-overview
Kind regards
I have been looking around but was unable to find a comprehensive overview similar to the one you have posted for the 9001. Where did you find this information (for the 9001 I mean) ?
For the 9901, you will probably have to piece it together, e.g. the maximum number of bridge domains can be found by issuing the command "show l2vpn capability"...
Hi Georg,
I took into consideration that is a typhoon card inside and then check into this link:
https://www.cisco.com/c/en/us/support/docs/routers/asr-9000-series-aggregation-services-routers/213255-asr-9000-ethernet-line-cards-tr-and-se.html
DAVID-DPF
Thankyou,
i am migrating from ASR9006 to ASR9901.
My router has FULL INTERNET ROUTING with 2 ISP in Global VRF, and has 2 other VRFs with default route because 3 VRF with 2 ISP and with full internet routing (1M Routes per VRF) is not enough memory in ASR9006.
The ASR9901 has 4M Ipv4 routes in FIB , but is enough for 3 VRF with full Internet routing and 2 ISP?
Thanks you
DAVID
