How to configure Cisco 4221 with 2 Internet ISPs (DUAL WAN)
wanumet
Hello Members,
I want to configure Cisco ISR 4221 with 2 internet links, both working as 1.
Kindly assist
Hello
See attached.
Kind Regards
Paul
you need NAT in both interface toward ISP
you need default route toward both ISP same AD and metric
that it
MHM
balaji.bandi
if you looking to bundle both internet links in to 1 - that is limitation (until they are terminated from same ISP and ISP offer bundling)
If they are different ISP then you can load share between the ISP
check example config as below :
https://www.balajibandi.com/?p=1643
BB
Hello
See attached.
Kind Regards
Paul
