ASR 9904 major alarm
ansilrehmanfti
ASR 9904 using DC V2 power supply its major alarm persist after turn on power supply , it’s disappear only after remove and re-insert the power module, can anyone know the cause?
It could be a faulty unit or possibly a bad connection?
Do this happen every time you turn the power supply on?
Can you replace the power supply with a known good one to see if it works without having to re-insert? If the new PS works then the other PS might be bad or have bad connectors.
If that doesn't work then I would also look at the power source to see if its supplying enough power.
-David
To be specific ,generating alarm related to the power source, but problem is once we off power source A it generate power alarm related to the source A but it doesn't go once we normalize power , it remains  util remove and reinsert the module , in this time when we switched off power source B  alarm only showing for power source A.
It seems you have a faulty power source A. Do an RMA.
BR
****Kindly rate all useful posts*****
