ASR not supporting Vlans
jack samuel
Dear
I am trying to create a layer 2 vlan and interface vlan SVI and these commands are not available ,Do ASR routers can act a  layer 3 switches???
Please find the attached screen shot.
Lei Tian
Hi Jack,
You can create bridge domain on ASR, but not VLAN. Similar to what you bridge interfaces on other router platform. What are you trying to achieve?
HTH,
Lei Tian
Dear,
I want to create hsrp between the 2no's  ASR  routers for my below firewalls,when i went in the interface configuration mode there is no switchport mode trunk command.
Is it ASR doesn't act as a Layer 3 switch??
If they are not then i have to a put a switch between ASR and Firewall and connect these 2No's ASR and Firewall on these switches to aciheve the redundancy.
You will need a switch and you will need to use sub interfaces on the ASR.
