ASR ROUTING
davejumby
the following is an output of my int brief
Gi0/0/0.12 10.0.0.1 YES manual up up
Gi0/0/1.12 10.20.0.1 YES manual up up
and the following is my ip route on the vrf where the above interfaces are forwarding
S* 0.0.0.0/0 [1/0] via 10.20.0.2
10.0.0.0/8 is variably subnetted, 4 subnets, 3 masks
C 10.0.0.0/29 is directly connected, GigabitEthernet0/0/0.12
L 10.0.0.1/32 is directly connected, GigabitEthernet0/0/0.12
C 10.20.0.0/30 is directly connected, GigabitEthernet0/0/1.12
L 10.20.0.1/32 is directly connected, GigabitEthernet0/0/1.12
I'm not able to pass traffic from 10.20.0.1 to 10.0.0.1 and vice varsa. I'm testing this using the command " ping vrf <vrf-name> 10.0.0.1 source 10.20.0.1. Traceroute will work since it is a directly connected interfaces. Guys I really need help , I know it seems so simple I must be missing something here
6 Replies 6
with VRFs you would need some sort of route leaking. Post the config of your ASR...
here it is, its pretty basic ....I dont have any access lists
Building configuration...
Current configuration : 12703 bytes
! Last configuration change at 09:38:55 EAT Tue Oct 30 2018 by admin
version 16.7
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname HQSC-IEG-1
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
vrf definition HQSC-MTNEDGE-VRF
description " internet VRF"
rd 64884:1
address-family ipv4
exit-address-family
aaa new-model
aaa authentication login default local enable
aaa authentication login console local enable
aaa authentication enable default enable
aaa authorization console
aaa authorization config-commands
aaa authorization exec default local if-authenticated
aaa session-id common
clock timezone EAT 3 0
no ip bootp server
no ip domain lookup
ip domain name nf.kenya.co.ke
ip cef accounting non-recursive
subscriber templating
enrollment selfsigned
revocation-check none
no license smart enable
diagnostic bootup level minimal
redundancy
mode none
cdp run
interface TenGigabitEthernet0/0/0
no ip address
shutdown
interface TenGigabitEthernet0/0/1
no ip address
shutdown
interface GigabitEthernet0/0/0
description "LINK TO DC SWITCH 1"
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
negotiation auto
interface GigabitEthernet0/0/0.12
description " INTERNET CONNECTION To DC SWITCH"
encapsulation dot1Q 12
vrf forwarding HQSC-MTNEDGE-VRF
ip address 10.0.0.1 255.255.255.248
no ip redirects
interface GigabitEthernet0/0/1.12
description INTERNET LINK
ip address 10.20.0.1 255.255.255.252
no ip redirects
as far as I can tell you have only one VRF, but Vlan 12 is configured twice, with different IP addresses ?
as of now there is just one vrf , I want both sub-interfaces to be in vlan 12 , I am able to ping the next hops of the respective sub-interfaces but I just cant ping between the sub-interfaces if use ping vrf <vrf-name > 10.0.0.1 source 10.20.0.1. and hence the next hops of the respective sub-interfaces (10.0.0.2 and 10.20.0.2) cannot ping each other which is essentially what I'm trying to achieve.
This is the only way to do it in this environment , kindly help
I have added the "ip routing" command ,now the sub-interfaces  (10.0.0.1 , 10.20.0.1 )can ping each other but the next hops still cannot ping each other  (10.0.0.2 , 10.20.0.2 ). I believe I'm missing something pretty simple here kindly help guys
Hi.
Some questions.
Can you ping each of the other sides of the Point-to-Point interfaces? From HQSC-IEG-1
ping vrf HQSC-MTNEDGE-VRF 10.20.0.2
ping vrf HQSC-MTNEDGE-VRF 10.0.0.x
for subinterfaces 0/0/0.12 and 0/0/1.12 are the other sides in a vrf also? or the other sides are in a global routing table? I ask you this, because, it seems that may be devices in network 10.20 does not have the way back to network 10.0.0.1 and vice versa.
this can be solved adding a default route or a DG on those devices pointing to HQSC-IEG-1.
If the interfaces on those devices are inside a vrf, the default route or DG must be in that vrf. If the interfaces are in the global routing table, with just a static route / DR or DG should fix the problem.
Examples:
From device connected to 0/0/0.12
ip route 0.0.0.0 0.0.0.0 10.0.0.1
or (in case the other side be in the same vrf)
ip route vrf HQSC-MTNEDGE-VRF 0.0.0.0 0.0.0.0 10.0.0.1
From device connected to 0/0/1.12
ip route 0.0.0.0 0.0.0.0 10.20.0.1
ip route vrf HQSC-MTNEDGE-VRF 0.0.0.0 0.0.0.0 10.20.0.1
BR
Gaston
