ASR subnet not NAT processed
Evan Roggenkamp
I have two ASR 901 routers who can't seem to get  out to the internet sourcing an EVC SVI which should be the inside NAT  network.
NAT ROUTER:
interface FastEthernet0/0.120
encapsulation dot1Q 120
ip address dhcp
ip nat outside
ip virtual-reassembly in
interface FastEthernet0/0.200
encapsulation dot1Q 200
ip address 192.168.200.1 255.255.255.0
ip nat inside
ip nat inside source list 1 interface FastEthernet0/0.120 overload
Standard IP access list 1
    10 permit any log (6 matches)
ASR:
interface GigabitEthernet0/1
negotiation auto
synchronous mode
cdp enable
synce state slave
service instance 2 ethernet
  encapsulation dot1q 4000
  rewrite ingress tag pop 1 symmetric
  bridge-domain 4000
service instance 3 ethernet
  encapsulation dot1q 200
  bridge-domain 200
interface Vlan200
ip address 192.168.200.3 255.255.255.0
ip route 0.0.0.0 0.0.0.0 192.168.200.1
ip route vrf MGMT 0.0.0.0 0.0.0.0 10.4.1.1
There is a ME3400 in between the ASR and NAT router
I've checked that the VLAN is included on trunk and exists on switch.
Can ping 192.168.200.1 from both ASR
Any ideas what is happening here? Have I configured EVC wrong?
Buy you can ping from the ASR to the fa0/0.200 IP ?
If so can you temporarily change your NAT acl to be -
access-list 101 permit ip 192.168.200.0 0.0.0.255 any
and then redo the NAT statement to use that acl and retest.
It probably won't make a difference but i have seen it work in a few instances.
Jon
7 Replies 7
Jon Marshall
Haven't used EVCs so i may be of limited help but what does "sh ip nat translations" show on the NAT router ?
Jon
Hi Jon
Posted in service provider forum, but this is a tricky one because it is hard to be sure if this is NAT, EVC, or something else!
Here is the output after ping
NAT-ROUTER#sh ip nat translations
Pro    Inside global              Inside local               Outside local            Outside global
icmp 207.191.158.141:5    192.168.200.1:5       208.67.220.220:5      208.67.220.220:5
Not sure i understand the NAT output ie.
the inside local is the IP assigned to the NAT router but i would have expected that to be an IP coming from the ASR ?
Jon
Ah, that was after pinging on the NAT router itself. Pinging from the ASR yields no additional entries. Furthermore, "debug ip NAT" on the NAT router, then ping to the internet on the ASR - seems there is no activity.
Jon
Thanks Jon you saved me a lot of headache for today. Slight change on the ACL and it all works fine!
No problem, glad it worked.
Just for your info i think you could have used a standard acl as well and just specified the source network.
Some people recommend that but i have always use extended acls with NAT and it seems to work fine.
Jon
