ASR1000-ESP5
TuralLachinov
I have Cisco ASR 1002 with ASR-ESP5 module.
ASR1002 /  ASR1000-ESP5 / SPA-2XOC12-POS
Cisco IOS Software, IOS-XE Software (PPC_LINUX_IOSD-ADVENTERPRISEK9-M), Version 12.2(33)XNF2, RELEASE SOFTWARE (fc1)
System image file is "bootflash:asr1000rp1-adventerprisek9.02.06.02.122-33.XNF2.bin"
Everything work properly, till I began to configure ssh on the version 12.2 I met the below problem.but on the version of IOS 15  ASR1000-ESP5 is not rebooted at all, and disconnects the module. Please see the below log and help please.
BGW-2.ASR-1002#sh platform
Chassis type: ASR1002
Slot      Type                State                 Insert time (ago)
0         ASR1002-SIP10       ok                    20:13:15
0/0      4XGE-BUILT-IN       ok                    20:11:35
0/1      SPA-2XOC12-POS      ok                    20:11:35
R0        ASR1002-RP1         ok                    20:13:15
R0/0                         ok, active            20:13:15
R0/1                         ok, standby           20:11:06
F0        ASR1000-ESP5        ok, active            20:13:15
P0        ASR1002-PWR-AC      ok                    20:12:25
P1        ASR1002-PWR-AC      ok                    20:12:24
Slot      CPLD Version        Firmware Version
0         07120202            12.2(33r)XNC
R0        08011017            12.2(33r)XNC
F0        07091401            12.2(33r)XNB
============   When i tried to configure ssh ---============================================================
0         ASR1002-SIP10       ok                    20:14:27
0/0      4XGE-BUILT-IN       ok                    20:12:47
0/1      SPA-2XOC12-POS      ok                    20:12:47
R0        ASR1002-RP1         ok                    20:14:27
R0/0                         ok, active            20:14:27
R0/1                         ok, standby           20:12:18
F0        ASR1000-ESP5        disconnecting         20:14:27
P0        ASR1002-PWR-AC      ok                    20:13:37
P1        ASR1002-PWR-AC      ok                    20:13:36
=============== logs ====================
*Apr  3 13:45:28 Dush: %IMGR-0-FIPS_FMFP_N2_SEVERE_ERR_FAIL: F0: fman_fp_image:  Cryptographic coprocessor severe failure: RSA operation error .
*Apr  3 13:45:28 Dush: %ASR1000_OIR-6-OFFLINECARD: Card (fp) offline in slot F0
==========  Here I Reloaded the module which did not help  ===========================
BGW-2.ASR-1002#hw-module slot F0 reload
BGW-2.ASR-1002#sh platform | i ASR1000-ESP5
F0        ASR1000-ESP5        init, active          20:17:08
F0        ASR1000-ESP5        ok, active            20:17:18
F0        ASR1000-ESP5        disconnecting         20:17:29
===========  After reloding the router ======================================================
*Apr  3 13:47:11 Dush: %HSRP-5-STATECHANGE: GigabitEthernet0/0/3 Grp 0 state Standby -> Active
*Apr  3 13:47:49 Dush: %ASR1000_OIR-6-ONLINECARD: Card (fp) online in slot F0
*Apr  3 13:48:05 Dush: %CPPHA-7-START: F0: cpp_ha:  CPP 0 preparing image /tmp/sw/fp/0/0/fp/mount/usr/cpp/bin/cpp-mcplo-ucode
*Apr  3 13:48:05 Dush: %CPPHA-7-START: F0: cpp_ha:  CPP 0 startup init image /tmp/sw/fp/0/0/fp/mount/usr/cpp/bin/cpp-mcplo-ucode
*Apr  3 13:48:12 Dush: %CPPHA-7-START: F0: cpp_ha:  CPP 0 running init image /tmp/sw/fp/0/0/fp/mount/usr/cpp/bin/cpp-mcplo-ucode
*Apr  3 13:48:13 Dush: %CPPHA-7-READY: F0: cpp_ha:  CPP 0 loading and initialization complete
*Apr  3 13:48:17 Dush: %IOSXE-6-PLATFORM: F0: cpp_cp: Process CPP_PFILTER_EA_EVENT__API_CALL__REGISTER
*Apr  3 13:48:24 Dush: %IMGR-0-FIPS_FMFP_N2_SEVERE_ERR_FAIL: F0: fman_fp_image:  Cryptographic coprocessor severe failure: RSA operation error .
*Apr  3 13:48:25 Dush: %ASR1000_OIR-6-OFFLINECARD: Card (fp) offline in slot F0
*Apr  3 13:48:31 Dush: %BGP-5-ADJCHANGE: neighbor 91.200.216.241 Down BGP Notification sent
*Apr  3 13:48:31 Dush: %BGP-3-NOTIFICATION: sent to neighbor 91.200.216.241 4/0 (hold time expired) 0 bytes
*Apr  3 13:48:33 Dush: %BGP_SESSION-5-ADJCHANGE: neighbor 91.200.216.241 IPv4 Unicast topology base removed from session  BGP Notification sent
*Apr  3 13:49:41 Dush: %CPPHA-3-FAULT: F0: cpp_ha:  CPP:0 desc:CPP Client process failed: FMAN-FP det:HA class:CLIENT_SW sev:FATAL id:1 cppstate:RUNNING res:UNKNOWN flags:0x0 cdmflags:0x0
*Apr  3 13:49:41 Dush: %IOSXE-6-PLATFORM: F0: cpp_ha: Shutting down CPP MDM while client(s) still connected
*Apr  3 13:49:41 Dush: %PMAN-3-PROCHOLDDOWN: F0: pman.sh:  The process fman_fp_image has been helddown (rc 134)
*Apr  3 13:49:41 Dush: %PMAN-3-PROCHOLDDOWN: F0: pman.sh:  The process cpp_ha_top_level_server has been helddown (rc 69)
*Apr  3 13:49:41 Dush: %PMAN-0-PROCFAILCRIT: F0: pvp.sh:  A critical process fman_fp_image has failed (rc 134)
*Apr  3 13:49:43 Dush: %CPPDRV-3-LOCKDOWN: F0: cpp_cp:  CPP10(0) CPP Driver LOCKDOWN due to fatal error.
*Apr  3 13:50:01 Dush: %BGP-5-ADJCHANGE: neighbor 195.246.102.3 Down BGP Notification sent
*Apr  3 13:50:01 Dush: %BGP-3-NOTIFICATION: sent to neighbor 195.246.102.3 4/0 (hold time expired) 0 bytes
*Apr  3 13:50:17 Dush: %BGP_SESSION-5-ADJCHANGE: neighbor 195.246.102.3 IPv4 Unicast topology base removed from session  BGP Notification sent
*Apr  3 13:50:56 Dush: %ASR1000_OIR-6-ONLINECARD: Card (fp) online in slot F0
*Apr  3 13:51:10 Dush: %CPPHA-7-START: F0: cpp_ha:  CPP 0 preparing image /tmp/sw/fp/0/0/fp/mount/usr/cpp/bin/cpp-mcplo-ucode
*Apr  3 13:51:11 Dush: %CPPHA-7-START: F0: cpp_ha:  CPP 0 startup init image /tmp/sw/fp/0/0/fp/mount/usr/cpp/bin/cpp-mcplo-ucode
*Apr  3 13:51:16 Dush: %CPPHA-7-START: F0: cpp_ha:  CPP 0 running init image /tmp/sw/fp/0/0/fp/mount/usr/cpp/bin/cpp-mcplo-ucode
*Apr  3 13:51:17 Dush: %CPPHA-7-READY: F0: cpp_ha:  CPP 0 loading and initialization complete
*Apr  3 13:51:21 Dush: %IOSXE-6-PLATFORM: F0: cpp_cp: Process CPP_PFILTER_EA_EVENT__API_CALL__REGISTER
*Apr  3 13:51:27 Dush: %IMGR-0-FIPS_FMFP_N2_SEVERE_ERR_FAIL: F0: fman_fp_image:  Cryptographic coprocessor severe failure: RSA operation error .
*Apr  3 13:51:27 Dush: %BGP-5-ADJCHANGE: neighbor 195.246.102.3 Up
*Apr  3 13:51:28 Dush: %HSRP-5-STATECHANGE: GigabitEthernet0/0/3 Grp 0 state Active -> Speak
*Apr  3 13:51:28 Dush: %ASR1000_OIR-6-OFFLINECARD: Card (fp) offline in slot F0
*Apr  3 13:51:40 Dush: %HSRP-5-STATECHANGE: GigabitEthernet0/0/3 Grp 0 state Speak -> Standby
Tural L
0 Replies 0
