asr1000 evc on portchannel
Hello. We have asr1006 with 2 esp-40 and 2 rp2 and 2 sip-40. we need to bridge vlan from portchannel (2*10) to single 10ge port.
so fn said that EVC on Port-Channel supported on our software and document
http://www.cisco.com/en/US/docs/ios-xml/ios/cether/configuration/xe-3s/asr1000/ce-mac-addlmt-bdsin.html#GUID-8010AC31-10A7-40BE-9240-B179D24F0AC3
have such example
2.    configure terminal
3.    interface port-channel channel-group
4.    service instance id ethernet
but on our router we have not service command on port-channel. only on non portchannel interface.
but other document have:
Restrictions for Configuring EVCs on the Cisco ASR 1000 Series Router The following features are not supported: EVC on Etherchannels
and:
connect ww port-channel 1 2 tenGigabitEthernet 0/1/0 2
this is possible command on our router (but i can't create service instance on portchannel interface)
we need to bridge l2 without l3 termination ? is this possible with port-channel ?
up... very important feature
IOS XE Version: 03.09.00a.S (this is from csr1000v)
interface Port-channel1
service instance 1 ethernet (have this command).
