ASR1000 -OID
Toss Leey
 I got below OID for ASR- CPU, but when i use through SNMP it show not recognize, I search and I found OID 1.3.6.1.4.1.9.9.109.1.1.1.1.24 it works, but the extension 2,3 and 4 when add not retrive any info. any one can help
.1.3.6.1.4.1.9.9.109.1.1.1.1.24.2  RP0
.1.3.6.1.4.1.9.9.109.1.1.1.1.24.3  ESP0
.1.3.6.1.4.1.9.9.109.1.1.1.1.24.4  SIP0
also where i can find memory, Temp. OID for ASR, because I found a lot of MIB files, and I do not now in which MIB file these OID
anyone can help;
Toss Leey
When i check CPU utilization on ASR it show to me the values are zero
#show processes cpu
CPU utilization for five seconds: 0%/0%; one minute: 0%; five minutes: 0%
but when I used SNMP with OID: .1.3.6.1.4.1.9.9.109.1.1.1.1.24. , I got different result like 28, or 50, so is that mean this OID not correct?
Object: cpmCPULoadAvg1min
Description: The overall CPU load Average in the last 1 minute period
