ASR1001 BDI interface
khld.saad
i have configured BDI interface on ASR Router (ex BDI 100) And given it Test IP 10.1.1.1/24 and it is UP and server with IP 10.1.1.2/24 can Ping BDI interface
but when we shutdown one of Sw interface ( Ex: SW-01 Port Fa0/1 ) , Ping fails .
It seems that only interface Fa0/1 on SW-01 is working and traffic going through it , but when it shutdown the interface Fa0/2 on SW-02 doesn’t carry traffic
we need to know why this happens and how we make redundancy in this case .
- The configuration on ASR Router as below :-
interface GigabitEthernet0/0/1
no ip address
negotiation auto
cdp enable
service instance 100 ethernet
encapsulation untagged
bridge-domain 100
interface GigabitEthernet0/0/2
no ip address
negotiation auto
cdp enable
bridge-domain 100
interface BDI100
ip address 10.1.1.1 255.255.255.0
no snmp trap link-status
snmp ifindex persist
make sure you have spanning tree enabled globally (spanning-tree mode rapid-pvst)...
Also add the 'l2protocol peer stp' command to your interfaces:
no ip address
negotiation auto
cdp enable
l2protocol peer stp
bridge-domain 100
no ip address
negotiation auto
cdp enable
l2protocol peer stp
bridge-domain 100
interface BDI100
the command not available with me as below
(config-if)#l2protocol peer ?
<cr>
can you post the full configuration is your ASR ?
Building configuration...
BFD feature is not supported
Current configuration : 51839 bytes
! Last configuration change at 13:53:06 UTC Wed Nov 7 2018 by m.aly
! NVRAM config last updated at 13:08:16 UTC Wed Oct 24 2018 by m.aly
version 16.7
service timestamps log datetime msec localtime year
service password-encryption
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
logging userinfo
logging buffered 1048576
aaa new-model
aaa group server tacacs+ ACS
ip vrf forwarding Mgmt-intf
ip tacacs source-interface GigabitEthernet0
aaa authentication login default group ACS local
aaa authorization exec default group ACS local
aaa accounting exec default start-stop group ACS
aaa session-id common
login on-failure log
login on-success log
subscriber templating
redundancy
mode none
track 3 ip sla 3 reachability
delay down 15
track 30 list boolean or
object 3
object 31
object 32
object 33
track 31 ip sla 31 reachability
delay down 15
track 32 ip sla 32 reachability
delay down 15
track 33 ip sla 33 reachability
delay down 13
track 40 list boolean or
object 41
object 42
object 43
object 44
track 41 ip sla 41 reachability
track 42 ip sla 42 reachability
track 43 ip sla 43 reachability
track 44 ip sla 44 reachability
interface Loopback1
no ip address
shutdown
interface Loopback2
description test
no ip address
shutdown
interface Loopback100
no ip address
shutdown
interface Loopback101
no ip address
shutdown
interface Port-channel4
no ip address
shutdown
negotiation auto
lacp fast-switchover
lacp max-bundle 2
interface TenGigabitEthernet0/0/0
no ip address
shutdown
interface TenGigabitEthernet0/0/1
no ip address
shutdown
interface GigabitEthernet0/0/0
description > WAN - B5-sw2-Gi0/3 <
no ip address
load-interval 30
shutdown
negotiation auto
interface GigabitEthernet0/0/1.880
description > WAN - B 30Mbps <
encapsulation dot1Q 880
shutdown
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/3
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/4
no ip address
shutdown
negotiation auto
cdp enable
bridge-domain 100
interface GigabitEthernet0/0/5
no ip address
shutdown
negotiation auto
cdp enable
bridge-domain 100
description << B5- >
ip address 10.0.x.x 255.255.255.0
negotiation auto
interface BDI100
ip address x.x.x.x 255.255.255.128
shutdown
ip forward-protocol nd
no ip http server
ip http authentication local
no ip http secure-server
ip tftp source-interface GigabitEthernet0
line con 0
session-timeout 15
exec-timeout 5 0
timeout login response 180
stopbits 1
line aux 0
stopbits 1
line vty 0 4
session-timeout 15
access-class Management in vrf-also
exec-timeout 5 0
transport input ssh
line vty 5 15
session-timeout 15
exec-timeout 5 0
transport input ssh
ntp server vrf Mgmt-intf prefer
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
end
