[ASR1001] CRITICAL, All Fans Failed
fabienfs
I have a critical led that lit up on my ASR1001.
With the command "show facility-alarm status", I have this :
System Totals  Critical: 4  Major: 2  Minor: 0
Source              Severity      Description [Index]
Power Supply Module 0      CRITICAL      Power Supply Failure [0]
Power Supply Module 0      CRITICAL      All Fans Failed [1]
Power Supply Module 0      MAJOR         Fan 0 Failure [3]
Power Supply Module 1      CRITICAL      Power Supply Failure [0]
Power Supply Module 1      CRITICAL      All Fans Failed [1]
Power Supply Module 1      MAJOR         Fan 0 Failure [3]
What seems odd to me is that at one time I would have a problem with the fans on my two power supplies?
I do not understand that it happens at the same time on both.
Could this be another problem?
thanks
best regards,
fabienfs
After reboot,the alarms are gone
Leo Laohoo
Can someone visually inspect the power supplies?  This could either be CSCvc16495 or CSCvi23510.
Hello Leo, visually everything seems to be working normally
It looks like the bug mentioned on the links. But is there no solution explained?
thanks
 - The first one has a Known fixed releases advisory ,
  M.
fabienfs
