03-29-2019 11:46 AM
We have here a ASR1001-X (IOS XE 3.16.06S) with "adventerprise" license, running as BNG with the following features enabled:
BGP (to export automatically address from subscribers with static valid IP)
PPPOE Server (BNG, approximately 1300 subscribers)
CGNAT PBA based (approximately 20000 NAT sessions)
show license feature Feature name Enforcement Evaluation Subscription Enabled RightToUse adventerprise yes yes no yes yes advipservices yes yes no no yes ipbase no no no no no avc yes yes no no yes broadband no no no no no broadband_4k no no no no no cube_250 no no no no no cube_250_red no no no no no cube_ent_100 no no no no no cube_ent_100_red no no no no no cube_lab no no no no no cube_video_b2btp no no no no no cube_video_b2btp_red no no no no no firewall no no no no no fpi no no no no no fwnat_red yes yes no no yes gtp_addon_aic no no no no no internal_service yes no no no no ipsec yes yes no no yes lawful_intr yes yes no no yes lisp yes yes no no yes nat64_stateful_2m no no no no no otv yes yes no no yes sgt_fw no no no no no sw_redundancy yes yes no no yes throughput_5g yes yes no no yes throughput_5g_to_10g yes no no no no throughput_5g_to_20g yes no no no no throughput_10g yes yes no no yes throughput_10g_to_20g yes no no no no throughput_20g yes yes no no yes vpls yes yes no no yes interface_10g yes yes no no yes FoundationSuiteK9 yes yes no no yes AdvUCSuiteK9 yes yes no no yes
show platform hardware throughput level The current throughput level is 2500000 kb/s
The big question:
Since we don't have a specific Broadband license or a CGN license, how could this happen?
Adventerprise enable those features?
One last info, I was able to connect 8000 subscribers (in lab) but no able to throughput beyond the 2500000 kb/s (2.5Gbps).
03-29-2019 01:20 PM - edited 03-29-2019 01:21 PM
ASR 1000-X Default as below :
The built-inembeddedserviceprocessorof the CiscoASR 1001-XRoutersupportsthroughputsof 2.5 Gbps(default)
if you like to have mode you need to enable evaluation license (for 60days) in the config "platform hardware throughput level 10000000" for 10GB"
here is reference guide :
03-29-2019 01:45 PM
Im aware of the throughput limit.
My doubt is about license for PPPOE/CGN...
03-29-2019 02:49 PM
I have not used Carrier Grade License.
here is the guide for reference : (hope this will help you)
04-01-2019 07:34 AM - edited 04-01-2019 07:35 AM
Thanks friend
Right, lets start over
My doubt is not about how license works in Cisco ASR 1001-X, I know that I have to buy license and stuff
My doubt is how it is working NOW since we dont buy any license except the ADVENTERPRISE.
Thanks!!
04-01-2019 09:01 AM
Apologies - not sure if i get the right or not
Let me clarify here :
ADVENTERPRISE - with this by default you get 2.5GB
Some of the features you have enabled as Evaluation, that will work until they expiry.
Hope this make sense, or still cross wired ?
04-01-2019 09:41 AM
Ok,
"ADVENTERPRISE - with this by default you get 2.5GB"
ok, no problem until here.
show pppoe summary per subinterface PTA : Locally terminated sessions FWDED: Forwarded sessions TRANS: All other sessions (in transient state) TOTAL PTA FWDED TRANS TOTAL 1197 1188 0 9
show license all
License Store: Primary License Storage StoreIndex: 0 Feature: adventerprise Version: 1.0 License Type: Permanent License State: Active, In Use License Count: Non-Counted License Priority: Medium License Store: Built-In License Storage StoreIndex: 0 Feature: adventerprise Version: 1.0 License Type: EvalRightToUse License State: Inactive Evaluation total period: 8 weeks 4 days Evaluation period left: 8 weeks 4 days Period used: 0 minute 0 second License Count: Non-Counted License Priority: None StoreIndex: 1 Feature: advipservices Version: 1.0 License Type: EvalRightToUse License State: Active, Not in Use, EULA not accepted Evaluation total period: 8 weeks 4 days Evaluation period left: 8 weeks 4 days Period used: 0 minute 0 second License Count: Non-Counted License Priority: None StoreIndex: 2 Feature: avc Version: 1.0 License Type: EvalRightToUse License State: Active, Not in Use, EULA not accepted Evaluation total period: 8 weeks 4 days Evaluation period left: 8 weeks 4 days Period used: 0 minute 0 second License Count: Non-Counted License Priority: None StoreIndex: 3 Feature: fwnat_red Version: 1.0 License Type: EvalRightToUse License State: Active, Not in Use, EULA not accepted Evaluation total period: 8 weeks 4 days Evaluation period left: 8 weeks 4 days Period used: 0 minute 0 second License Count: Non-Counted License Priority: None StoreIndex: 4 Feature: ipsec Version: 1.0 License Type: EvalRightToUse License State: Active, Not in Use, EULA not accepted Evaluation total period: 8 weeks 4 days Evaluation period left: 8 weeks 4 days Period used: 0 minute 0 second License Count: Non-Counted License Priority: None StoreIndex: 5 Feature: lawful_intr Version: 1.0 License Type: EvalRightToUse License State: Active, Not in Use, EULA not accepted Evaluation total period: 8 weeks 4 days Evaluation period left: 8 weeks 4 days Period used: 0 minute 0 second License Count: Non-Counted License Priority: None StoreIndex: 6 Feature: lisp Version: 1.0 License Type: EvalRightToUse License State: Active, Not in Use, EULA not accepted Evaluation total period: 8 weeks 4 days Evaluation period left: 8 weeks 4 days Period used: 0 minute 0 second License Count: Non-Counted License Priority: None StoreIndex: 7 Feature: otv Version: 1.0 License Type: EvalRightToUse License State: Active, Not in Use, EULA not accepted Evaluation total period: 8 weeks 4 days Evaluation period left: 8 weeks 4 days Period used: 0 minute 0 second License Count: Non-Counted License Priority: None StoreIndex: 8 Feature: sw_redundancy Version: 1.0 License Type: EvalRightToUse License State: Active, Not in Use, EULA not accepted Evaluation total period: 8 weeks 4 days Evaluation period left: 8 weeks 4 days Period used: 0 minute 0 second License Count: Non-Counted License Priority: None StoreIndex: 9 Feature: throughput_5g Version: 1.0 License Type: EvalRightToUse License State: Active, Not in Use, EULA not accepted Evaluation total period: 8 weeks 4 days Evaluation period left: 8 weeks 4 days Period used: 0 minute 0 second License Count: Non-Counted License Priority: None StoreIndex: 10 Feature: throughput_10g Version: 1.0 License Type: EvalRightToUse License State: Active, Not in Use, EULA not accepted Evaluation total period: 8 weeks 4 days Evaluation period left: 8 weeks 4 days Period used: 0 minute 0 second License Count: Non-Counted License Priority: None StoreIndex: 11 Feature: throughput_20g Version: 1.0 License Type: EvalRightToUse License State: Active, Not in Use, EULA not accepted Evaluation total period: 8 weeks 4 days Evaluation period left: 8 weeks 4 days Period used: 0 minute 0 second License Count: Non-Counted License Priority: None StoreIndex: 12 Feature: vpls Version: 1.0 License Type: EvalRightToUse License State: Active, Not in Use, EULA not accepted Evaluation total period: 8 weeks 4 days Evaluation period left: 8 weeks 4 days Period used: 0 minute 0 second License Count: Non-Counted License Priority: None StoreIndex: 13 Feature: interface_10g Version: 1.0 License Type: EvalRightToUse License State: Active, Not in Use, EULA accepted Evaluation total period: 8 weeks 4 days Evaluation period left: 8 weeks 3 days Period used: 2 minutes 1 second License Count: 0/0 (In-use/Violation) License Priority: Low StoreIndex: 14 Feature: FoundationSuiteK9 Version: 1.0 License Type: EvalRightToUse License State: Active, Not in Use, EULA not accepted Evaluation total period: 8 weeks 4 days Evaluation period left: 8 weeks 4 days Period used: 0 minute 0 second License Count: Non-Counted License Priority: None StoreIndex: 15 Feature: AdvUCSuiteK9 Version: 1.0 License Type: EvalRightToUse License State: Active, Not in Use, EULA not accepted Evaluation total period: 8 weeks 4 days Evaluation period left: 8 weeks 4 days Period used: 0 minute 0 second License Count: Non-Counted License Priority: None
No BROADBAND information on "show license all"
We have no RTU for Broadband, all EvalRightToUse stay with default value (no countdown).
Active PPPOE Session TOTAL: 1197
Uptime 4 months.
How is this possible to have 1197 session with no license?!?! Is ADVENTERPRISE contains Broadband RTU?
show ip nat translations total Total number of translations: 25468
25468 CGN translations, no license for that too.
04-09-2019 10:49 AM
As I expected
It's a mystery...
04-09-2019 12:15 PM
To be honestly never come across that luck, cisco never give that kind of apportuity give you ability use.
So i would not make any sounds.....................! Keep Calm start using until it work.. (make sense ?)
