12-15-2015 05:14 AM - edited 03-05-2019 02:56 AM
I have a new MPLS Route Reflector to configure in an ASR1001-X and I need to add the address-family vpnv4 under bgp but I don´t have that command available. Do you know why? Do I need to activate any additional feature or license to have it?
Thanks in advance!
(rr2.bal6) dkccqrt04nt00fm#sh ver
Cisco IOS XE Software, Version 03.13.02.S - Extended Support Release
Cisco IOS Software, ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.4(3)S2, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Fri 30-Jan-15 14:23 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2015 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
dkccqrt04nt00fm uptime is 3 days, 23 hours, 48 minutes
Uptime for this control processor is 3 days, 23 hours, 49 minutes
System returned to ROM by reload
System image file is "bootflash:/asr1001x-universalk9.03.13.02.S.154-3.S2-ext.SPA.bin"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: ipbase
License Type: Default. No valid license found.
Next reload license Level: ipbase
cisco ASR1001-X (1NG) processor (revision 1NG) with 3751700K/6147K bytes of memory.
Processor board ID FXS1912Q2Z5
6 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
8388608K bytes of physical memory.
6688767K bytes of eUSB flash at bootflash:.
dkccqrt04nt00fm(config-router)#address-family ?
ipv4 Address family
ipv6 Address family
l2vpn Address family
nsap Address family
dkccqrt04nt00fm(config-router)#address-family ipv4 ?
flowspec Address Family modifier
mdt Address Family modifier
multicast Address Family modifier
mvpn Address Family modifier
unicast Address Family modifier
vrf Specify parameters for a VPN Routing/Forwarding instance
<cr>
dkccqrt04nt00fm(config-router)#address-family ipv4 un
dkccqrt04nt00fm(config-router)#address-family ipv4 unicast ?
<cr>
dkccqrt04nt00fm(config-router)#address-family ipv4 unicast vrf ?
WORD VPN Routing/Forwarding instance name
dkccqrt04nt00fm(config-router-af)#?
Router Address Family configuration commands:
aggregate-address Configure BGP aggregate entries
auto-summary Enable automatic network number summarization
bgp BGP specific commands
default Set a command to its defaults
default-information Control distribution of default information
default-metric Set metric of redistributed routes
distance Define an administrative distance
distribute-list Filter networks in routing updates
exit-address-family Exit from Address Family configuration mode
help Description of the interactive help system
maximum-paths Forward packets over multiple paths
neighbor Specify a neighbor router
network Specify a network to announce via BGP
no Negate a command or set its defaults
redistribute Redistribute information from another routing protocol
snmp Modify snmp parameters
synchronization Perform IGP synchronization
table-map Map external entry attributes into routing table
dkccqrt04nt00fm(config-router-af)#exit
ipv4 Address family
ipv6 Address family
nsap Address family
% Incomplete command.
dkccqrt04nt00fm(config-router)#address-family ipv6 ?
<cr>
dkccqrt04nt00fm(config-router)#address-family ipv6 un
dkccqrt04nt00fm(config-router)#address-family ipv6 unicast ?
<cr>
dkccqrt04nt00fm(config-router)#exit
dkccqrt04nt00fm(config)#router bgp 25384
ipv4 Address family
ipv6 Address family
nsap Address family
dkccqrt04nt00fm(config-router)#address-family l2vpn ?
evpn Address Family modifier
vpls Address Family modifier
<cr>
dkccqrt04nt00fm(config-router)#end
(rr2.bal6) dkccqrt04nt00fm#sh license all
License Store: Primary License Storage
License Store: Built-In License Storage
StoreIndex: 0 Feature: adventerprise Version: 1.0
License Type: EvalRightToUse
License State: Active, Not in Use, EULA not accepted
Evaluation total period: 8 weeks 4 days
Evaluation period left: 8 weeks 4 days
Period used: 0 minute 0 second
License Count: Non-Counted
License Priority: None
StoreIndex: 1 Feature: advipservices Version: 1.0
StoreIndex: 2 Feature: avc Version: 1.0
StoreIndex: 3 Feature: fwnat_red Version: 1.0
StoreIndex: 4 Feature: ipsec Version: 1.0
StoreIndex: 5 Feature: lawful_intr Version: 1.0
StoreIndex: 6 Feature: lisp Version: 1.0
StoreIndex: 7 Feature: otv Version: 1.0
StoreIndex: 8 Feature: sw_redundancy Version: 1.0
StoreIndex: 9 Feature: throughput_5g Version: 1.0
StoreIndex: 10 Feature: throughput_10g Version: 1.0
StoreIndex: 11 Feature: throughput_20g Version: 1.0
StoreIndex: 12 Feature: vpls Version: 1.0
StoreIndex: 13 Feature: interface_10g Version: 1.0
License Count: 0/0 (In-use/Violation)
Solved! Go to Solution.
12-15-2015 05:25 AM
I see you have ipbase license level installed. You might have to select the license level as advipservices license level.
I dont think vpnv4 is supported in ipbase license level. Even for the EvalRightToUse license, It is not in use as you might have not accepted the EULA agreement.
Please follow the below CCO document to accept the right to use.
http://www.cisco.com/c/en/us/td/docs/routers/asr1000/configuration/guide/chassis/asrswcfg/csa_rtu.html
Hope this helps.
Vinit
12-15-2015 05:25 AM
Hope this helps.
Vinit
12-15-2015 08:47 AM
Hi Vinit,
thank you! I applied:
conf t
license boot level advipservices
reload
conf t
license accept end user agreement
And now I was able to add the vpnv4 address-family
Now, I am trying to see if I need to permanently activate the licenses (I don´t want to have it expired in some months).
(rr2.bal6) dkccqrt04nt00fm#sh license eula
Feature name EULA Accepted
adventerprise no
advipservices yes
ipbase n/a
avc no
broadband n/a
broadband_4k n/a
cube_250 n/a
cube_250_red n/a
cube_ent_100 n/a
cube_ent_100_red n/a
cube_lab n/a
cube_video_b2btp n/a
cube_video_b2btp_red n/a
firewall n/a
fpi n/a
fwnat_red no
gtp_addon_aic n/a
internal_service n/a
ipsec no
lawful_intr no
lisp no
nat64_stateful_2m n/a
otv no
sgt_fw n/a
sw_redundancy no
throughput_5g no
throughput_5g_to_10g n/a
throughput_5g_to_20g n/a
throughput_10g no
throughput_10g_to_20g n/a
throughput_20g no
vpls no
interface_10g no
