Showing results forĀ
Search instead forĀ
Did you mean:Ā
ASR1001X Software Installation Failure
Ihabmoussa
I have two ASR1001x and I am trying to install the software version
asr1001x-universalk9_npe.16.07.01.SPA.bin
on the first  device, the installation worked properly. Everything is OK.
However on the second one, I have alsways the same failure message:
ROM:RSA Self Test Passed
ROM:Sha512 Self Test Passed
Self Tests Latency: 58 mSec
Package header rev 1 structure detected
Calculating SHA-1 hash...done
validate_package_cs: SHA-1 hash:
calculated b49f8674:8797558b:496e7b80:69e18511:47cb882e
expected b49f8674:8797558b:496e7b80:69e18511:47cb882e
Signature verification failed for key# 2
Signature verification failed for key# 3
Failed to validate digital signature
RSA Signed REVOCATION Image Signature Verification Failed.
Package Load Test Latency : 7913 mSec
signature verification FAILED...
boot: error executing "boot bootflash:asr1001x-universalk9_npe.16.07.01.SPA.bin"
autoboot: boot failed, restarting...
Could you please help me with this problem ?
3 Accepted Solutions
 - Check ROMMON version , you may need a ROMMON upgrade, look at Release Notes for version you are trying to install and rommon compatibility ,
 M.
gajownik
System Bootstrap, Version 15.4(2r)S, RELEASE SOFTWARE (fc1)
Copyright (c) 1994-2014 by cisco Systems, Inc.
You have affected ROMMON by below bug:
CSCur94666 Code-signed images greater than 512M fail to load
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCur94666
ROMMON upgrade is required
https://software.cisco.com/download/home/284932298/type/282046486/release/17.3(1r)
BTW 16.7 image will be EoL in a week:
https://www.cisco.com/c/en/us/products/collateral/routers/asr-1000-series-aggregation-services-routers/eos-eol-notice-c51-740376.html
Leo Laohoo
Upgrade the ROMMON.
Please refer to to the link below for instructions on how to upgrade the firmware (in Install Mode) and ROMMON in one reboot.
Cisco ISR & ASR 1k Routers: IOS-XE/Firmware Upgrade (Install Mode)
9 Replies 9
marce1000
  - Verify
 md5sum
of the image that you are trying to install ,
 M.
I verified it
..................................................................................................................................................................................................................................................................................................................................................................................................................................................Done!
Verified
(flash:asr1001x-universalk9_npe.16.07.01.SPA.bin) = 9338d02ca9e980363a2195216a0875c3
the image seems to be ok. It works properly on the other router
 M.
Console into the router and reboot.  Post the entire
boot-up
process.
If the router is still in ROMMON, post the complete output to the command
set
The router is not in the rommon mode.
I installed an old image on it to check the conf settings
Here is the entire
boot-up
proces.
gajownik
Thank you!!
It is solved
Leo Laohoo
Upgrade the ROMMON.
Thanks!
